Old 10-22-2001, 12:15 AM   #1
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Will first gear be at the top right...where 5th would be on a left hand driver?
5th    3rd      1st
        4th       2nd
thanks,
M
mbmbmb23 is offline   Reply With Quote
Old 10-22-2001, 04:27 AM   #2
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
No it's the same as a US shifter. 1st is in the upper left corner still.
ca18guy is offline   Reply With Quote
Old 10-22-2001, 10:43 AM   #3
Guest
Posts: n/a
im guessin its a japan RHD tranny... interesting question so i suppose the shfits for RHD are 1 2 3
                                                          4 5 r
Old 10-22-2001, 12:32 PM   #4
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
alll shifters have 1st in the top left
japan is not in reverse......
drifterx is offline   Reply With Quote
Old 10-22-2001, 02:44 PM   #5
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
VWs are different, They're Top: R 1 3 space and then Bottom: Space 2 4 5. Am I right?
S13Grl is offline   Reply With Quote
Old 10-22-2001, 06:36 PM   #6
BlankFlip
BlankFlip's Avatar
BlankFlip is an unknown quantity at this point
i don't know about vw's, but nissan's should be the same as the U.S. cars.
BlankFlip is offline   Reply With Quote
Old 10-22-2001, 08:07 PM   #7
HaloZ
HaloZ is an unknown quantity at this point
Send a message via AIM to HaloZ
they are all the same. nissan that is.
135
24R
HaloZ is offline   Reply With Quote
Old 01-14-2002, 05:14 AM   #8
DjBaMBaM
DjBaMBaM is an unknown quantity at this point
Send a message via ICQ to DjBaMBaM
IS the tranny any better than the stock one? As a matter of fact, what is the stock tranny? Any what 6-speed trannys can be put in a 240? TIA.
DjBaMBaM is offline   Reply With Quote
Old 01-14-2002, 09:35 AM   #9
White240sx
White240sx is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from DjBaMBaM on 5:14 am on Jan. 14, 2002
IS the tranny any better than the stock one? As a matter of fact, what is the stock tranny? Any what 6-speed trannys can be put in a 240? TIA.</td></tr></table><span id='postcolor'>
I believe the RB tranny is the same as the old FJ tranny, but I’m not sure. The stock 5-speed is the same one used on the SR powered cars; it's good beyond the power level anyone is ever going to reach on pump gas. Even the 10-second S14 which was putting an estimated 520hp through the tranny survived street duty and a little track abuse. As far as 6-speeds go, the S15 tranny is always there, but you will need the S15 drive shaft, rear diff, and the axels. Then there is the Quaife drop-in gear set; 6-speed, dog engagement spur cut gears. Racing tranny only, will set you back $8k to $10k.
White240sx is offline   Reply With Quote
Old 01-14-2002, 09:49 AM   #10
pinoy nismo
pinoy nismo is an unknown quantity at this point
correct me if im wrong guys..........do you mean i could use an rb trany &nbsp;to convert my autotrany to manual
my car is a s14a 200sx with an sr20det engine. &nbsp;
pinoy nismo is offline   Reply With Quote
Old 01-14-2002, 10:44 AM   #11
mistert
Pearl White Mike
mistert is an unknown quantity at this point
Send a message via ICQ to mistert Send a message via AIM to mistert
it'd be possible to mate them up, yes, but it'd be simpler to just use an SR tranny. it'll require some hacking to get an RB tranny to hook up to an sr20det. mounting it is no problem, though. the rb25det tranny is very built compared to the rb20det tranny, as well. when rb26dett is used in a RWD application the rb25det trans is always used
mistert is offline   Reply With Quote
