Old 12-06-2007, 12:19 AM   #1
kamikazekid
kamikazekid's Avatar
kamikazekid is making a name for him/her selfkamikazekid is making a name for him/her self
the infamous....
Check engine light. need to pass smog, tipical stock KA with the anoying check engine light on. what do i need to do to clip the wire and turn it off for good?
Drifting is not a crime
kamikazekid is offline   Reply With Quote
Old 12-06-2007, 12:32 AM   #2
916S14
916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known916S14 is making his/her stupidity well-known
Well it depends if you got OBD1 or 2. You might as well go to a local car parts store and rent the little scanner tool and fix the problem. Most likely its your Evap, those go bad all the time.
916S14 is offline   Reply With Quote
Old 12-06-2007, 12:33 AM   #3
Dousan_PG
Dousan_PG's Avatar
wire the oil pressure and engine light together
haha
assuming ur pre '94
pray your actual emission output is ok too.
Aaron
Pink GodziRa
Old 12-06-2007, 12:37 AM   #4
kamikazekid
haha
assuming ur pre '94
it passes the sniffer but the dam light keeps failing the test. wheres the wire on the ECU i need to cut?
Old 12-06-2007, 12:39 AM   #5
kamikazekid
its OBD1, its just a stock hatch. it pulls up 32 ( EGR). but i checked it and replaced it. still comes on though.
Old 12-06-2007, 12:45 AM   #6
Dousan_PG
Dousan_PG's Avatar
read what i said again until you undrestand
turn ur car on
watch the oil pressure come on
and turn off
imagine if u wired your engine like to that same wire what would happen?
Aaron
Pink GodziRa
Old 12-06-2007, 12:48 AM   #7
yarou
yarou's Avatar
yarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfection
turn ur car on
and turn off
Yeah, he's right. To pass smog they need to see your CEL blink when you turn your car on with all the other lights. If you just cut the wire and the CEL doesn't show during start up, it won't pass.
jumbosandbox.blogspot.com
yarou is offline   Reply With Quote
Old 12-06-2007, 12:54 AM   #8
kamikazekid
dam i never thought of that. well this is why i asked the question. thanks guys.
Old 12-06-2007, 01:01 AM   #9
mrmephistopheles
mrmephistopheles's Avatar
oil pressure or battery.
Strange thing though - Nissan put that there to let you know when your engine isn't working right. Why would you want to drive around with a questionable engine?
Originally Posted by PHLIP
Old 12-06-2007, 08:17 AM   #10
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
if you replaced the valve then there are only 4 other possibility's.
1. The EGR solenoid is bad
2. Other EGR passage is clogged
3. The wiring from the ECU to the solenoid is shorted
4. The ECU is bad.
First test, pull a vaccum on the EGR valve while the engine idles, If the engine stalls then you the Valve is working and the passage is clear.
Second test, unplug the solenoid and use 2 pieces of wire to provide ground and B+ from the battery to the solenoid. If the engine stalls then you know that the solenoid is working.
Third test, use a test light or multi-meter. Allos engine to reach normal operating temp. Unplug selnoid and raise rpm to 2500. If you recieve power on 1 pin and ground on the other than you know that the wiring and the computer are good and working. If you do not recieve power on either pin than check that same wire @ the ECU.
Good luck!
RedtopTech is offline   Reply With Quote
Old 12-06-2007, 04:56 PM   #11
RedtopTech
RedtopTech's Avatar
EGR is used at part throttle acceleration and cruise to lower combustion temps in order to reduce oxides of nitrogen (NoX). I rec. that you get it working.
Old 12-06-2007, 05:04 PM   #12
!Zar!
!Zar!'s Avatar
haha
assuming ur pre '94
Haha.
I do that all the time.
sshhhiiittt
OP: Don't cut anything. If you want to simply not deal with the light, take the bulb out of the cluster.
But smog techs will fail your car if the light doesn't illuminate when they turn your car off/on.
That's why you wire it to your oil light.
And then once you are driving and your oil/check engine light come on for real, you'll know you're fucked.
Just what a check engine light should do.
haha.
Old 12-06-2007, 06:13 PM   #13
SR_Elliott24
SR_Elliott24 will become famous soon enoughSR_Elliott24 will become famous soon enoughSR_Elliott24 will become famous soon enough
Send a message via AIM to SR_Elliott24
Autozone will let you use theirs for free. Went down there with my buddies mustang and got the codes.
SR_Elliott24 is offline   Reply With Quote
Old 12-06-2007, 06:19 PM   #14
kamikazekid
all very good ideas and points. ill wire it to the oil light for smog then switch it back later.
Old 12-06-2007, 06:30 PM   #15
Rob's S14
Rob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfectionRob's S14 is close to perfection
Send a message via AIM to Rob's S14
let me know if that works. i'm having the same problem too, with the egr code coming up. luckily i won't have to smog til september at the earliest.
Rob's S14 is offline   Reply With Quote
Old 12-06-2007, 11:18 PM   #16
!Zar!
!Zar!'s Avatar
Just spray a bottle of throttle body cleaner in to the egr.
Prior to smogging a car, it was reading 3000k+ nox.
After cleaning, it read 280 or something.
Huge ass difference.
Old 12-07-2007, 12:05 AM   #17
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
did you try and reset the ecu after you fixed the real problem. could be the code is just stored in the ecu memory
onepuff is offline   Reply With Quote
