Old 12-11-2007, 12:53 PM   #1
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
How to remove bearing from diff pinion gear?...
How do you remove the bearing that is on the diff pinion gear shaft?...
I'm trying to use the S15 pinion gear shaft with the S13's smaller bearing... I happened to have a 4.36 final drive from an S15 lying around so I thought I might as well put it in...
Nikeboy355 is offline   Reply With Quote
