Old 12-15-2007, 05:45 PM   #1
Doluck
Doluck is on the path to ruinDoluck is on the path to ruinDoluck is on the path to ruin
SR TPS reading 10v at wot??
On a friend of mines car: Its a NA RWD SR20DE
ok i checked (wht) signal and (blk) ground also battery ground
adjusted so that closed throttle is .49
and wot is 10v
Everywhere i check says it should be a little over 4v wot
half throttle i get 5v though.
i dont think its the sensor because it gradually goes up as i turn the potentiometer...(i think i spelled that right )
also not a faulty ground because the battery ground is the same as the tps ground.
could it be wiring?
Doluck is offline   Reply With Quote
Old 12-15-2007, 06:02 PM   #2
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
replace the tps. that reading's 5v's off lol. even if it goes up gradually that's a good start
that's weird tho
MURPHY is offline   Reply With Quote
Old 12-15-2007, 06:03 PM   #3
kuppler8
kuppler8's Avatar
kuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-knownkuppler8 is making his/her stupidity well-known
Send a message via AIM to kuppler8
is he having any drivabilty issues?
kuppler8 is offline   Reply With Quote
Old 12-15-2007, 06:08 PM   #4
Doluck
nope..........
Old 12-15-2007, 06:26 PM   #5
RPS13nutt
RPS13nutt is a well-known jackass
there really is no issue normal driving,
as for getting on it, the car pulls easier when i let off the gas a little, lol.
probably because the 5v on half throttle
so i just wanted to check the tps and found 10v wide open
I will borrow another tps to see if it does the same thing
RPS13nutt is offline   Reply With Quote
Old 12-15-2007, 11:28 PM   #6
cotbu
cotbu's Avatar
Is he getting power from the ecu or a 12v source.
Old 12-15-2007, 11:36 PM   #7
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
No way is it possible to get a 10v reading when its only suppose to be supplied 5 volts. Something is fucked up
undesiredshoe is offline   Reply With Quote
Old 12-15-2007, 11:44 PM   #8
cotbu
cotbu's Avatar
yes and yes the wiring, I doubt the ecu is fubar check another sensors voltage like mafs
Old 12-16-2007, 01:41 AM   #9
RPS13nutt
yeah 12v is comming from the ecu
I'll check the maf soon, i was over a friends house when i used the multimeter
I'll buy one and see
Old 12-16-2007, 01:54 AM   #10
Gnnr
Gnnr's Avatar
Have you checked it with another meter?
Gnnr is offline   Reply With Quote
Old 12-16-2007, 02:19 AM   #11
GSXRJJordan
GSXRJJordan's Avatar
lol I'm surprised no one caught that before Gnnr - if the MAF's getting 12V instead of 5V, nothing would be running correctly. It's probably just the multimeter ~
Old 12-20-2007, 10:55 PM   #12
RPS13nutt
finally got my hands on another multimeter, and it turns out to be the meter was faulty,
thanks for the help on this
Old 12-21-2007, 05:07 AM   #13
GSXRJJordan
Good, thanks for not leaving the thread hanging.
"El Jefe the Wiring Guru" was right again! lol
/thread.
Old 12-27-2007, 05:25 PM   #14
EM_S13
EM_S13 is making a name for him/her selfEM_S13 is making a name for him/her selfEM_S13 is making a name for him/her self
Send a message via AIM to EM_S13
Ha ha, good thing. I was going to ask if you had set your multimeter correctly
1992 S13
I WORK I Apexi I HKS I Greddy I Sparco I Cusco I Tomei I
EM_S13 is offline   Reply With Quote
