Old 12-27-2007, 09:43 AM   #1
sildrift86
sildrift86's Avatar
sildrift86 is an unknown quantity at this point
Starting Issues
Now before you all say SEARCH!
I did, I went through about 15 threads all containing starting problems and none were specific to my situation.
well, a wile back I moved the TPS a notch to adjust the idle and just recently the only way to start up the car is by having the gas peddle pressed down all the way (WOT), if not the car will just keep on cranking over and never start.
I think if I just replace the TPS it should fix the starting problem wile keeping my idle normal.
But before I go replacing expensive parts and sensors with no hope on fixing my problems I want to see what you guys think?
Its kinda embarrassing when theres people around and you want to start your car and you have to wait a couple of seconds while your starter is screaming trying to make your car start.
Help?
I have a 91' 240sx
Thanks
sildrift86 is offline   Reply With Quote
