![]() Join Date: May 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
car wont go into gear, and when does moves
seems as if the clutch isnt engaging or something...... i couldnt get the clutch to engage and noticed that the throw out fork wasnt working at all. so we pulled the tranny and noticed that the throw out bearing was jacked.... we then put a new tranny in with another throw out bearing and put it all back together. bled the clutch etc. etc. etc....... when the car isnt running it goes through gears fine but when its on that dumb hoe wont go into gear..... and when it does go into gear it moves. as if the clutch is not fully engaging?
any ideas...... sorry for being a noob but i cant find shit. i love you bye bye |
![]() Join Date: Jan 2007
sounds like the clutch is dragging, check your adjustment at the pedal, it' a threaded rod with a jam nut, and make sure you didn't bend your fork or break your pivot ball.
all i can think of checking. |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
First off make sure your m/c and s/c aren't leaking. Look on the firewall under the master cyl inside the car if it is wet then the m/c is leaking. Pull back the dust boot on the slave cyl if there is fluid in there then it is bad. Also check the clutch pedal adjustment. It should have about 1/2" of play at the pedal.
#5 |
so i checked on the inside of the car on the firewall and it is leaking a little bit from what seems to be the master cylinder...... could this be the reason its doing it. or is that not enough to make it act like that?
#7 |
Definitely replace it, but DON'T GO TO AUTOZONE! Unless you feel like replacing it again in a couple of months. Do a little searching and find a source for a tokico one it will be about the same price. Hell autozone might be able to get you one, just stay away from duralast or some other cheap ass crap.
#8 |
![]() Join Date: May 2002
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 23 reviews
ive been using that autozone shit for my master and slave for over 1.5 years on the track car
actually ive used that on all mycar for the past 5 years.. shit works fine install drive its cool get some sweet ass speed bleeder too for the slave makes life easy! |
#10 |
![]() Join Date: Oct 2006
Haha no problem, but yeah I had an Autozone master cyl. on my old fastback and I beat the shit out of that car and the master lasted a year and when I sold the car it was still holding up like a champ.
#11 |
No problem man! I've got a tokico master and slave on my car and I've been running them for 2.5 years. As a matter of fact they were on my red coupe for like 1.5 years then I wrecked it and now they've been on my fastback for a year. Buy quality parts, it will always pay off in the end.
#12 |
http://www.frsport.com/Clutch-Pedal---Parts_c_43.html just bought a slave and master myself from these guys.
#13 |
Definitely don't goto autozone or kragen. You'll be replacing the master cylinder again in 12 months or less. I had my clutch fork bend on my truck and I got to learn how to shift with no clutch. I knew if I left my truck at work it would be gone or stripped the next day so I had no choice.
#14 |
![]() Join Date: Apr 2004
You can drive without using the clutch but you have to learn how to revmatch perfectly. One screwup and you'll fry the synchros.
New OEM master cylinder, new OEM or Nismo slave cylinder, throw away the damper box, and get a Taka Motorsports braided line from master to slave to make your life easier. It should take less than 5 repititions to bleed without the damper. With the damper you need a power bleeder. |
#16 |
ok so i replaced the master cylinder, slave clyinder, throw out bearing, fork, and new tranny...... but the car still doesnt go into gear very easily while it is running. it can be done but it has to be forced. and once it is in gear and the clutch is in the car starts moving unless i am on the brakes... it shifts from 1st to second fine and from 3rd to forth fine but the main problem is while im stopped it is trying to go. about to go try and adjust the play at the clutch problem
#18 |
well as of yesterday the problem was fixed...........
but guess what...... its not fixed anymore i drove it today for the first time and it got me to work fine and dandy... on the way home from work im going straight and just hear metal grinding again..... so im like wtf? i just put that throw out bearing in.....i havent got to look at it yet but i am almost positive that it is the throw out bearing....... so i drive home without a clutch and now am sitting here thinking how nice it was to drive my car for the 20 minuts that it lasted? so my question to you is why did this happen again???? could i be installing the throw out bearing wrong???? |
#19 |
im gonna put a new one in tommorow but im nervous because i dont want this one to mess up agian because it will be my third one
some one please help a retard |
#20 |
![]() Join Date: Jul 2003
I had a similar problem after going to a after market clutch. I think your clutch is not being fully disengage.
1. A quick test is with the engine off put it in 1st gear. 2. Start the car. 3. If the cars move forward then your clutch is not disengaging properly. Solution: 1. Try adjusting the clutch engagement point which you've done. 2. Replace the slave with a nismo one. 3 Try extending the rod in the slave by putting it in a 8mm socket. If this works, fab yourself up a longer rod. |
#21 |
so what would cause me to keep messing up throw out bearings?
i dont want to put another one in there and mess it up again? what would cause this? could it be the pressure plate? |
#26 |
When you took the trans down, did you put in a new clutch too? Check to see if the clutch fork pivot ball is broken. Make sure your clutch fork is properly installed (with the little spring clip). Make sure you properly bleed your clutch system afterwards. You should be able to watch the slave cylinder move the clutch fork from above.
#27 | |
![]() Join Date: Dec 2002
haha i had to do that a few weeks ago when my clutch went out on the way to work |
#28 | |
ding ding ding! winner! |
