Old 01-08-2008, 08:17 AM   #1
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
cold start issues on ka-t, coolant temp sensor?
i'm having a little idle problem with my ka-t when starting the car up during colder temps outside. the colder it gets, the more prevelant the problem is.
when i start the car, it idles at approx 1100-1200rpm for about a minute, very smooth with no problems. after which the afr's drop off the chart, meter displays LEAN and the car stumbles like crazy, sometimes even dies. restarting is not a problem, starts right up but stumbles for a while. it stumbles for about 3 or so minutes till the water temps increase, then the idle smooths out. if i start driving the car slowly shortly after start-up, the stock water temp gauge bounces back and forth a little. the problem goes away after about 10 minutes of driving.
i was under the assumption that during cold starts, the car would run pig rich instead of lean all the way.......
my guess would be that the coolant temp sensor is going bad, or the connection to it. i got one on the way, just wondering if anyone had similar problems, or has other ideas.
thanks!
pacefarm is offline   Reply With Quote
Old 01-08-2008, 09:12 AM   #2
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
It could be your iacv valve iirc. I think that is the correct name. The valve controls the air coming in at idle. What you need to do is loosen the tube going to the valve, start the car, have some one keep it running, pull tube off, spray about half a can of intake cleaner down the tube, re-attach tube end to cold pipe.
Are you using a wideband o2 sensor monitor or just the regular af o2 gauge? The later is useless.
Replacing that temp sensor is always a good idea. It can only help but I believe it has nothing to do with your problem.
-Retired
98s14inaz is offline   Reply With Quote
Old 01-08-2008, 02:15 PM   #3
g6civcx
g6civcx's Avatar
There are 2 separate temp sensors: one for the gauge and one for the ECU. I don't think your gauge needle bouncing is related to the idle unless both sensors are damaged by something in that area.
