Old 01-26-2008, 12:41 PM   #1
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
coupe window molding removal
so im getting ready to start prepping my car for paint and i really dont want to skimp on the prep work.
I looked in the fsm for how to properly remove all the window moldings withough damaging them but I am having a hard time figuring out exactly how everything comes off. (dont want to pull too hard and break something ect)
for those of you who have done this before, what is the best way to take them off?
jim1234664 is offline   Reply With Quote
Old 01-26-2008, 02:40 PM   #2
projectRDM
projectRDM's Avatar
Pretty vague question, but I'll add what I can.
The belt moulding on the door is secured by a single screw at the back edge, above the door handle, remove it and life carefully, there's three clips across the door's edge. Helps to have the mirror off already but it's not required.
The driprail moulding is screwed in, pull the door opening weatherstrip down and you'll see the screws.
The rear window moulding snaps into place along the top and sides, the lower trim is screwed down. Usually when you pull the moulding it's damaged, so expect to replace it, or the better idea is to heat a run a stiff piece of wire under it, that will lift it off the body and allow you to paint underneath it. Same goes for the quarter windows, they're bonded to the glass and glued in, easier to just lift the moulding and paint underneath unless you plan to replace the glass.
FORMERLY R240NA
Old 01-26-2008, 02:48 PM   #3
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
good info projectrdm...im planning on doing the same thing to prep my car for paint
+rep
ecuastyle84 is offline   Reply With Quote
Old 01-26-2008, 06:29 PM   #4
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
What Russ (ProjectRDM) has said. The rear 1/4 windows are a bitch to replace and expensive. I regret taking my moldings off of them.
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline   Reply With Quote
