Old 02-01-2008, 09:03 AM   #1
neo_rambo
neo_rambo is an unknown quantity at this point
Sr20det A/C compressor won't kick on with console switch.
I had the a/c working for 3 years in a 91 hatch with an sr20det. Just recently I noticed that the compressor isn't kicking on with the interior control unit when I hit the A/C switch the green light doesn't come one but thats common with those consoles for the lights to go out on them. I check the fuse inside and that was good. I tested the relay with another relay that I know works. Still didn't kick in. I took the relay out and bypassed it with a wire and the compressor kicked in. Has anyone had this problem? What do you guys think it is? A/C Control unit the problem? Low pressure switch? Are there any other tests that I can do? Thanks in advance.
neo_rambo is offline   Reply With Quote
Old 02-01-2008, 02:25 PM   #2
projectRDM
projectRDM's Avatar
Pressure switch, you're low on refrigerant more than likely. The compressor does not engage if it's low.
FORMERLY R240NA
Old 02-01-2008, 05:54 PM   #3
neo_rambo
thanks man I will refill it and hopefully it will fix the problem.
