Old 02-11-2008, 01:56 PM   #1
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
clunk noise from trans when shifting at low RPM
i recently did a auto/manual conversion on my 96 240sx. everything was replaced during the swap, including master/slave, T.O. bearing, clutch fork, etc. my problem is this:
when shifting gears from 1-2 and from 2-3 at low RPM i get a clunking noise that appears to be coming from the transmission area. if i i take it much above 3k rpm the noise goes away and the shifts are pretty seamless. i have done quite a bit of searching and have come away with a few suggestions:
1. drivetrain slack
2. rear end bushings. sub-frame, diff, etc.
i was bored so i let a local mechanic drive it around the block, and his diagnosis was bad transmission gears or some shit, and offered to rebuild it for $1500. that price is ridiculous as fuck, and im hoping my problem has nothing to do with the actual transmission anyway. maybe i need a new driveshaft? any thoughts?
nep is offline   Reply With Quote
Old 02-11-2008, 02:03 PM   #2
180sx Fan
180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all180sx Fan is a name known to all
could be the stock drive shaft they are two piece and sometimes when they get old and used the rubber bushing thing that holds them together can wear out and when mine did it made a sort of cluncking sound you can check it out to make shure it is not that.
180sx Fan is offline   Reply With Quote
Old 02-11-2008, 03:25 PM   #3
nep
nep's Avatar
you refering to the part circled in red?
it did look weathered when i put it on, guess i could trade out the old one from my auto driveshaft. thanks. any other suggestions?
Old 02-11-2008, 07:10 PM   #4
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
Carrier bearing it sounds like. Reach under there and shake it and see if you get any movement in it.
Deftec is offline   Reply With Quote
Old 02-11-2008, 07:29 PM   #5
180sx Fan
nep: yes i am refering to the pice you circleded in red the little cage thing that holds it might also just be lose so you might wanna check that too.
Old 02-11-2008, 07:40 PM   #6
sleepy_s13
sleepy_s13's Avatar
sleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to beholdsleepy_s13 is a splendid one to behold
lol @ $1500 to rebuild a tranny. You put a pilot bearing in right?
K:\pics\Cars\new sig bridge copy.jpg
sleepy_s13 is offline   Reply With Quote
Old 02-11-2008, 11:18 PM   #7
evidens83
evidens83 is an unknown quantity at this point
Send a message via AIM to evidens83
BUMP! This auto-manual conversion s14 is the cleanest of North County San Diego!! Dang Nep I told you, forget about that clunk and think about some boost ya digg?!! lol
evidens83 is offline   Reply With Quote
Old 02-12-2008, 01:44 AM   #8
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
i have the same problem, but i hear grinds or so if shifting low rpm
importdude is offline   Reply With Quote
Old 02-12-2008, 11:57 AM   #9
nep
nep's Avatar
I'm obsessive-compulsive man, no rest for me until it shifts smoother than a pair of silk panties. and no boost until those student loans come in lol.
sleepy: yea I used a pilot bushing.
I found some local driveshafts, ill pick one up and see where that takes me
Old 02-12-2008, 12:07 PM   #10
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Nice to see that education fundage going for something useful..... LOL
As far as the clunking, definitely check the driveshaft carrier bearing. Also check the diff bushings, and driveaxles for excessive freeplay.
My drivetrain has a slight "clunk" when I first put it in gear while the clutch is still disengaged. I'm guessing it's the syncros just moving in the tranny. Some noises are not necessarily bad. Just typical wear and tear. And a KA drivetrain has ALOT of vibrations in stock form while working properly. That's just how they built them.
That mechanic is full of shit. He's just trying to make some cash. 1500 for a rebuild is ridiculous. Shit new intenals only cost about 300 bucks. All you need is a press and some gear pullers and you can do it yourself.
Or you can just source out another tranny for about 200 bucks. Done.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
