Old 02-12-2008, 06:19 AM   #1
mxsx25
mxsx25's Avatar
mxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-knownmxsx25 is making his/her stupidity well-known
Send a message via AIM to mxsx25
s13 sr wont rev past 3k
the car is a sileighty with an sr swap, mainly stock, it has an apexi boost controller and thats pretty much it, but the problem is that when under a load the car will not rev past 3k but it will do fine if not under a load, im thinking it may be a wastegate issue becuase it isnt really going into boost range, i guess it could be the tps or maf but just curious if anyone else has ran into this problem...any help would be appreciated
mxsx25 is offline   Reply With Quote
Old 02-12-2008, 06:30 AM   #2
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Either you have a problem with your MAF, or you have a massive boost/vacuum leak somewhere (i.e. intercooler hose popped off).
If you want more detailed info, search for one of the other 8000 threads on this topic, they CAN'T be that hard to find.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 02-12-2008, 07:06 AM   #3
180sxLove
180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about
MAF sensor is the reason why you cant rev past 3k.. unplug and see if the problems continue, they should.
Replace the MAF and it should be OK
180sxLove is offline   Reply With Quote
Old 02-12-2008, 08:01 AM   #4
Slow Poke
Slow Poke's Avatar
Slow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really niceSlow Poke is just really nice
You can also trying cleaning the MAF, that works sometimes as well. GL
Slow Poke is offline   Reply With Quote
Old 02-12-2008, 08:26 AM   #5
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
boost leak!!!!! But yeah, search first man cuz I had the same problem and had a similar thread, so there is info out there regarding this subject/ topic.
TOMKAIRA93 is offline   Reply With Quote
Old 02-16-2008, 10:22 AM   #6
mxsx25
mxsx25's Avatar
okay so i swapped out the maf sensor on the sr and tightened up all the hose clamps and checkd all vacuum/boost lines and the car runs great all except for it has what ive heard is a "hunting idle" i read to test the tps and the iac, i know how to test the tps but what should i be looking for when testing the IAC? and i thought i read somewhere that the sr throttle bodies have an idle screw which im guessing goes hand in hadn w. the IAC...anyways, thanks for the help and any input is deffinately appreciated
Old 02-16-2008, 10:31 AM   #7
240sx_sr20det
240sx_sr20det's Avatar
240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection240sx_sr20det is close to perfection
MAF has my vote. I have had the same problem before.
240sx_sr20det is offline   Reply With Quote
Old 02-16-2008, 11:15 AM   #8
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
So what if you changed out the MAF and it still has the problem? (my current situation )
StaticX27 is offline   Reply With Quote
Old 02-16-2008, 11:49 AM   #9
Tops*
Tops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfectionTops* is close to perfection
How cold is it over in NH? I don't know what a "hunting idle" is, but if you're talking about a stumbling idle, clean your IACV with some CAS throttle body cleaner. It's different from the CAS MAF sensor cleaner so don't get the two mixed up. There's a complete write up in the Zilvia archive, so search for it. The topic's been covered hundreds of times. The stumbling idle could also be caused by the low temps. While I let my car sit and warm up, the idle dips under 800 and shoots up to around 1500 sometimes until it completely warms up.
MADE IN JAPAN
Tops* is offline   Reply With Quote
Old 02-16-2008, 12:35 PM   #10
240sx_sr20det
Well on my S13, I changed the MAF and it was fine. I then bought an S14 and had the same problems, so I changed the MAF and still had the problem. It ended up being a bad injector that was causing it to run like shit.
I don't know if thats the same problem for you, but it worked for me.
Good-luck guys!
EDIT: ^^ It's frigid as hell in NH lately.
Old 02-18-2008, 08:12 AM   #11
jayesone
jayesone's Avatar
jayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the roughjayesone is a jewel in the rough
I had that same problem at the track, I blew a hole on my elbow, you cant hear it leak. but it wouldnt boost, but revs up fine. i suggest pull all the hot pipes and check them. I found that problem but now has another problem, my car wont boost past 13psi with out struggling.
jayesone is offline   Reply With Quote
Old 02-19-2008, 07:41 PM   #12
mxsx25
mxsx25's Avatar
well i found the problem causing my bad idle, and i am kicking myself for even asking for advice, haha, my coolant was leaking from where the hardline off the turbo meets a rubber line causing air to be in the system..i repaired the line, bled the system and it idles great now
