Old 02-14-2008, 01:56 PM   #1
lost240soul
lost240soul's Avatar
lost240soul is on the path to ruinlost240soul is on the path to ruinlost240soul is on the path to ruin
Reasons for high idle
so i just bought a 90 s13 ans it idles realli hi ...first idles normal than 1500 and now 2000 rpm ..any 1 have any idea
lost240soul is offline   Reply With Quote
Old 02-14-2008, 02:00 PM   #2
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
check for vacuum leaks.
What ideas have come up in your research of the problem?
Neejay is offline   Reply With Quote
Old 02-14-2008, 02:12 PM   #3
lost240soul
ok...i didnt really notice until now i have only had the car for like 3 days... the only think i can think of maybe something to do with the MAF sensor
Old 02-14-2008, 02:14 PM   #4
4bangers
4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices4bangers has made poor choices
check your IACV to see if it clog up. another thing is you could adjust your idle rpm by turning the screw on the IACV. that's what I did with my s13. But also make sure you didn't have a head gasket leak. good luck
4bangers is offline   Reply With Quote
Old 02-14-2008, 02:22 PM   #5
lost240soul
how would i check the iacv
Old 02-14-2008, 04:31 PM   #6
Neejay
Neejay's Avatar
Use the Search function and search for a FSM (you can type "s13 FSM" as the search string.)
Also use the Search to find out "how to check IACV". There's a lot of threads with the correct info.
Old 02-14-2008, 05:55 PM   #7
lost240soul
ahh thank u much... i figured it out... the guy that had my car before used a home depot screw were the idle screw went and it just kept moving down...
