Old 04-02-2008, 03:20 PM   #1
nismo240sxdrifter
nismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choicesnismo240sxdrifter has made poor choices
Suspension help
Can any of you help me, I have a 96 240 with 108k on it and it seems as if every time I step on the take my foot off of the brake quickly or if I quickly take my foot of the gas under accleration my back end make a clunck/thunk noise, I think it might just be struts beings that they are 12years old but I'm not sure if its more than that so if you guys could give me some help that would be much appreciated, thanks
nismo240sxdrifter is offline   Reply With Quote
Old 04-02-2008, 03:23 PM   #2
rhs13
rhs13's Avatar
rhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant future
Send a message via AIM to rhs13 Send a message via Yahoo to rhs13
im not trying to be a dick, but that can be a dozen different things. struts, subframe bushings, link bushings, loose/missing nuts/bolts, stuff in your trunk, some combination of the above or none of the above.
cuz i dont give a fukk. that's why.
rhs13 is offline   Reply With Quote
Old 04-02-2008, 03:30 PM   #3
airforceone451
airforceone451's Avatar
airforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enoughairforceone451 will become famous soon enough
Most definitely your subframe bushings...
airforceone451 is offline   Reply With Quote
Old 04-02-2008, 03:30 PM   #4
S13Junkie
S13Junkie's Avatar
S13Junkie is an unknown quantity at this point
very true I would recomend looking at the strut plates in the trunk and seeing if they are cracked and broken. if they are then that's probably it. if not then look under the car and check all of the subframe bushings and other suspension bushings and see if they are blown. hope this helps
S13Junkie is offline   Reply With Quote
Old 04-02-2008, 03:32 PM   #5
nismo240sxdrifter
I see thatbut I dont have anything in my trunk and i dont know how to describe it, it does it really bad in reverse when ever I acclerate and then let off of the gas, it's not like its undrivable or anything, its feels as if the back of the car bouces almost but it doesnt
Old 04-02-2008, 03:33 PM   #6
S13Junkie
S13Junkie's Avatar
this may sound weird but check all of your diff bolts and bushings I had the exact same thing happen on a 95 s14
Old 04-02-2008, 03:39 PM   #7
rhs13
rhs13's Avatar
agree. i might even go as far as making sure the cv joints on your axles arent messed up or your differential isnt messed up internally (broken teeth, etc.)
Old 04-02-2008, 03:41 PM   #8
nismo240sxdrifter
And what was wrong with it? When made my first reply about there being nothing in the trunk I was replying to the first guys post though, thanks I'll go check most of that stuff right now
Old 04-02-2008, 04:43 PM   #9
driftyour40
driftyour40's Avatar
driftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the roughdriftyour40 is a jewel in the rough
lol, yeah
subframe bushings, diff bushings, shocks/mounts, drive line slop.
most likely subframe and diff bushings.
driftyour40 is offline   Reply With Quote
Old 04-03-2008, 03:22 PM   #10
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
first check to see if your shocks are blown go push on the rear of the car down and watch the suspension if it oscillates, if so than its blown, fix rear shocks first, than move onto check subframe collars.
unless u want to go direct to collars ive got a used set for cheap PM me
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 04-03-2008, 04:45 PM   #11
Rnz520
Rnz520's Avatar
Rnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud ofRnz520 has much to be proud of
Send a message via AIM to Rnz520
Its most likely your subframe bushings, get some collars for a cheap fix but those will only last so long.
If you want to do it right get the aluminum solid ones, they are pretty cool.
My car used to make that before I put those on, then it stopped, but now my diff is making noises haha
*93 240sx:KA-T, FLTA-2s, MR TR, Greddy F&R bars, Greddy gauges, Cusco brace, etc
Rnz520 is offline   Reply With Quote
