Old 04-24-2008, 08:48 AM   #1
koolcat
koolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-knownkoolcat is making his/her stupidity well-known
Send a message via AIM to koolcat
Need help with a short!!!!!
I had this problem b4 but i though i fixed it and now it happened again. My head light (1992 s13) will not go down for some reason. Checked all fuse already, but the one that stop my headlight from flippping down is the RET MTR fuse in the fuse near the coolant resevoir. Everytime i put a new fuse in and click the headlight flipping button it would pop that fuse. So can someone show me a way to diagnose this short? Thanks in advance
koolcat is offline   Reply With Quote
Old 04-24-2008, 09:22 AM   #2
NorCalEvo
NorCalEvo's Avatar
NorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond reputeNorCalEvo has a reputation beyond repute
Send a message via AIM to NorCalEvo
sounds like its time to trace some wire bro. As screwed as it may sound its the only real way to make sure. I mean you can take a volt meter and test resistance in each wire on your service position button and that will give you a better idea as too which wire is failing or grounding, but in all reality I would just trace the group of them from the back of the button all the way to the fuse box and im sure you will find the problem. Feel free to pm if you have anymore questions. i will do what I can from here.
Drifting it one corner at a time.
NorCalEvo is offline   Reply With Quote
Old 04-24-2008, 10:47 AM   #3
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
if you have a power probe you can power the motor down with that and if it pops the fuse in the power probe then you can be absolutely sure that the problem is the motor itself. but based on speculation i think you should try a known good motor.
gl,
Dave @ Lethal Injection Motorsports (www.lethalmotorsports.com)
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 04-24-2008, 09:47 PM   #4
koolcat
sorry i don't even know what is a power probe and Norcalevo i never have a chance to go to check it with volt meter but once ill do it, ill get back at you for some more advice. Thanks man
