Old 04-24-2008, 01:32 PM   #1
jonnybonds84
jonnybonds84's Avatar
jonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to alljonnybonds84 is a name known to all
Rusty Cams
Searched around but no luck, how delicate are cams, I've tried cleaning them with a hard brisel brush but no luck. Someone told me to use a fine steel wool, what do you guys think? Fine sand paper? buffing it after? LMK.
jonnybonds84 is offline   Reply With Quote
Old 04-24-2008, 01:48 PM   #2
GSXRJJordan
GSXRJJordan's Avatar
I've used a 'fine' wire wheel. Basically, once you get the rust out, you're going to have 'pitting' where the rust ate away the steel. That's the big problem (how deep those pits are), not the rust itself. I like the wire wheel because it doesn't eat away at the cams like sandpaper would, but still gets all the rust out ~ if you have to grind the cams down to get them smooth again, just know that you're losing lift with every .010" you grind away.
Old 04-24-2008, 02:08 PM   #3
jonnybonds84
Ill try it and take some pics of it. Thanks.
Old 04-24-2008, 02:26 PM   #4
TougeLabs
TougeLabs's Avatar
TougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to beholdTougeLabs is a splendid one to behold
Send a message via AIM to TougeLabs
What motor do you have a have a set of sr13 sr cams as well as s14 sr cams
TougeLabs is offline   Reply With Quote
Old 04-24-2008, 02:37 PM   #5
jonnybonds84
They're s13 KADE cams, my s14 KA is waiting for them.
Old 04-24-2008, 02:45 PM   #6
deuceforty
deuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of lightdeuceforty is a glorious beacon of light
in case your in the need, i have a set of perfect s14 KA cams, with runners.
i also have an entire head, valves etc. no warps or anything
deuceforty is offline   Reply With Quote
Old 04-24-2008, 09:03 PM   #7
Dr.Baby
Dr.Baby's Avatar
Dr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud ofDr.Baby has much to be proud of
Send a message via AIM to Dr.Baby
ive had a bunch of cams rust on me before (left them in a car with the windows down not sealed...whoops), its all about using scotch brite pads (red or green is fine), buyem at your supermarket or whatever. takes a while, but work 1 lobe/cam journal at a time. if they pitted though...i wouldnt bother. ive had really good luck with doing that.
alexkors.com - blog.
AKdrift - twitter & facebook follow me!
Dr.Baby is offline   Reply With Quote
