Old 04-24-2008, 03:13 PM   #1
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
S14 Trans into S13 chassis
Anyone on here have this specific combo:
S14 manual trans into S13 chassis? If so does your speedometer read correctly if so which VSS did you use.
I currently have this setup but it seems after trying to S13 VSS my readings ares still doubled or so.
Im wondering if I need to use a S14 sensor? hmmmm
What I do know from searching is that it appear that a S13 VSS into a S14 chassis with SR20DET swaps seems to double the speed as well.
Old 04-24-2008, 03:19 PM   #2
94_240sx
94_240sx is on a distinguished road
I did this swap recently. 96 s14 tranny into s13 w/KA24DE. You need to use VSS from s13 DOHC manual tranny. As far as I know, SOHC VSS and DOHC VSS have 2 different part numbers for the gears.
Anyway, mine reads perfect.
94_240sx is offline   Reply With Quote
Old 04-24-2008, 03:34 PM   #3
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
ok, BTW mine tranny is from a 98 KA24DE...
Hmm this is kicking my ass my speed reads to fast and I am using a S13 VSS from a DOHC noted by the 20 tooth count.
Some SOHC came with a sport package, larger wheels equal different rolling diameter and came with 20 tooth count VSS the rest came with 21 tooth count VSS for SOHC.
Old 04-24-2008, 03:34 PM   #4
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
BTW was your car originally auto or 5 speed?
Old 04-24-2008, 04:00 PM   #5
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
jecs is ur cars cluster a sohc or dohc?
s13drob is offline   Reply With Quote
Old 04-24-2008, 06:19 PM   #6
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Its a DOHC I have a 91 240SX SE with H.U.D.
Old 04-24-2008, 06:23 PM   #7
s13drob
s13drob's Avatar
Trader Rating: (29)
hmmm... have u tried using another s13 DOHC sensor? thats the only thing i can think of
Old 04-24-2008, 06:48 PM   #8
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Yea I have, and I have it wired into my 5 speed lower harness which plugs in on the side of the fuse box.
Old 04-24-2008, 08:17 PM   #9
projectRDM
projectRDM's Avatar
VSS has to match the cluster. S13 cluster, S13 VSS. The transmissions are the same.
So in knowing that if you're speed is indeed doubled there's something strangely wrong. I've only heard of speeds being off using the wrong sensor for the chassis.
FORMERLY R240NA
Old 04-25-2008, 07:57 AM   #10
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Ok heres an update, I unpluged the ECU and pluged it back I also upluged the brown connector located under the dash just above the right corner of the glove back and pluged it back in and it started reading correctly aint that some shit but I think it had to do with the little brown connector, weird shit, thanks for your help everyone.
Old 04-25-2008, 08:18 AM   #11
94_240sx
That's cool. My car was auto originally. Yeah, when I did the swap. I removed battery cable and also swapped the ECU too.
If you search, you will see threads people saying speed shows double after the swap. Now, all they need to do is just unplug and plug back in. That's cool!!!
Old 04-25-2008, 08:21 AM   #12
94_240sx
You know what you are talking about. Yeah, that's what I found too from the dealership.
One more thing, I have both digital and regular clusters. I tried both and both of them work perfectly. Currently, I have digital cluster on my car.
Old 04-25-2008, 09:18 PM   #13
rowdogg03
rowdogg03's Avatar
rowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to allrowdogg03 is a name known to all
I just did this swap, put my sensor in new tranny.. works perfect..
My car is a 91 KADE and motor and tranny from a 96
not sure whats up with yours though..
Dippin
rowdogg03 is offline   Reply With Quote
Old 04-25-2008, 09:28 PM   #14
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Mine was tripping but now it works.
