Old 05-06-2008, 11:52 PM   #1
BC240
BC240's Avatar
BC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enoughBC240 will become famous soon enough
s14 Oil Leakdown?
Hey Guys,
During my brake install I had to let my car sit 3 days while waiting for a bolt, when I went to start it after I got spark but it wouldn't fire.. My friend who knows more about engines then I do said it was probably because it sat and the oil potentially leaked down from the cylinders?
Long story short he pinched the fuel line and had me try and start it, after a few minutes on and off it worked and started up with a puff of smoke.
He couldn't properly explain the implications of this, is this a symptom of a larger problem or should I relax.
Thanks
BC240 is offline   Reply With Quote
Old 05-07-2008, 05:49 AM   #2
just1pepsi
just1pepsi's Avatar
just1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfection
Send a message via MSN to just1pepsi
Hmm. not real sure what they were trying to tell you there. When an engine sits un-run for several days, any oil in the engine will run down to the lowest point, but it wouldnt have anything to do with it not starting (unless the engine were seized up, which obviously isnt the case) Maybe he was trying to say that your fuel pump lost its prime. which means the gas may have run backwards through the fuel line and back into your tank. This would cause you to have to "prime" it, or get fuel back up to the engine. Thats probably what he meant. Usually its not a problem, but it could also mean you have a pinhole in a fuel line somewhere.. I wouldnt worry about it immediately.
just1pepsi is offline   Reply With Quote
