Old 05-07-2008, 11:05 PM   #1
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
car dolly and rwd
my friend told me that i cant use a car dolly for my car but i dont see why. the car is rwd. i should be able to put it in nutral and roll wit it. i told him it was only awd you need a trailer. just for clearification reasons im asking all of you guys. thanks
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 05-07-2008, 11:11 PM   #2
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
I towed my 240 with a tow dolly no problem. If your not totally sure you can take out the drive shaft (takes like 10minutes), then your 100% good to go hahah.
DataXUnknown is offline   Reply With Quote
Old 05-07-2008, 11:13 PM   #3
whereda40at
thats what he told me that i would have to take the drive shaft out but i had it towed before and it was fine. no roll back just a snatcher.
Old 05-07-2008, 11:19 PM   #4
LongGrain
LongGrain's Avatar
some people say its not a good idea to dolly a RWD car because it just puts wear and tear on your drivetrain, since its spinning the whole time (hence the removal of driveshaft advice)
other than that, its no harm done.
LongGrain is offline   Reply With Quote
Old 05-07-2008, 11:23 PM   #5
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
I have seen a car that popped into gear...not a good thing for him! was for me ! I got a car cheap with a blown trans!
sillyvia13 is offline   Reply With Quote
Old 05-07-2008, 11:37 PM   #6
GSXRJJordan
GSXRJJordan's Avatar
Hahaha Sillyvia ~ that's called 'winning'.
Yeah, the whole argument is that it puts wear and tear on the drivetrain, and that it adds miles to your odometer. If you have a jack and jackstands to put the driveshaft back in on the other end, just do that.
Old 05-07-2008, 11:44 PM   #7
sumoboi7
sumoboi7's Avatar
sumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to allsumoboi7 is a name known to all
i think its ok. when some bitch got my cvar towed for parking an inch into the red zone next to her driveway that was still being cemented and was not in working condition they charged me extra cause my car was to low and they had to use a dolly. everything still seems fine.
RIP: black '89 s13 hatch
New: white '90 s13 hatch
sumoboi7 is offline   Reply With Quote
Old 05-08-2008, 09:37 AM   #8
LigouriRd
LigouriRd's Avatar
LigouriRd will become famous soon enoughLigouriRd will become famous soon enoughLigouriRd will become famous soon enough
Towing wheels down will put no more wear on the drive train than just normal driving...if you have a manual transmission. Auto's use the engine to pump the fluid around to keep things lubricated. Tow that wheels down and it will kill it.
Manuals just have oil sloshing around to keep them lubricated so no damage should be incurred. If your really worried, jam something around the shifter so i caint accidentally pop into gear.
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk
LigouriRd is offline   Reply With Quote
Old 05-08-2008, 10:03 AM   #9
jrbump
jrbump's Avatar
jrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond reputejrbump has a reputation beyond repute
Whatever you do, DO NOT tow it backwards.
I got paranoid around these very same issues and towed an S13 with the front wheels down. The car will sway back and forth all the way down the freeway, it had even my 3/4 ton dualie swaying. I tied the steering wheel down and everything, no dice.
It takes 10 minutes to DC the driveshaft, if you are truly worried do that.
jrbump is offline   Reply With Quote
Old 05-08-2008, 11:16 AM   #10
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
^You did not have the car on striaght then.
We have towed 6 S13s on tow dollys, and were with the rear wheels on the dolly and front on the ground. If its just a bit off from being even it will do that. We also leave the steering wheel in the locked position with the key out of the car. We stopped, moved the car a bit, and it was ok. We have towed them at 70-75 with no issues with a Chevy Colorado.
Only other problem we had was pulling a shell back that had bent rims and damaged suspension.
KA-T_240 is offline   Reply With Quote
Old 05-08-2008, 11:32 AM   #11
g6civcx
g6civcx's Avatar
Everybody stop right now and read this. Wheels turning auto + engine off = heat = fire
Never ever tow the driving wheels of an auto car on the ground, even if it's in N. Doesn't matter.
Best way is a flatbed. Second best way is to pick up the front and disconnect the driveshaft if auto. Third and barely acceptable way is to pick up from the back, but this is not stable at high speed and long distance.
End thread.
Old 05-08-2008, 12:16 PM   #12
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
I used the full trailer from Uhaul. It's a few bucks more from the POS two wheel dolly thing they offer.
flip3d is offline   Reply With Quote
