Old 05-08-2008, 09:52 PM   #1
bwake 5
bwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura aboutbwake 5 has a spectacular aura about
crazy rpm signal problem
i have the kouki s14sr20det in my 89 240sx.....
everything runs good and dandy
but i went to hook my safc2 up to it and it doesnt pick up rpm signal or throttle response
i have it hooked up to pin 2 on my ecu like apexi said......
even at idle it reads 0
i then cut this rpm wire to see if it was being grounded out......
the car would not even idle nor run....but it would read rpm's for the split second that it stayed running.....
i then reconnected this wire and it read 0rpm.....
weird.......
any ideas?
bwake 5 is offline   Reply With Quote
Old 05-12-2008, 10:34 PM   #2
bwake 5
bump please .
Old 05-13-2008, 12:53 AM   #3
makulit054
makulit054's Avatar
makulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of lightmakulit054 is a glorious beacon of light
This is what I found:
http://plxdevices.com/ECUDatabase/Ni..._SilviaS14.pdf
http://plxdevices.com/ECUDatabase/Ni...0DET_99_02.pdf
makulit054 is offline   Reply With Quote
Old 05-13-2008, 01:04 AM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
how did you connect the wires? i hope you soldered the wires and didn't use the little crimp things. I had the safc2 connected to my ecu and it ran fine along with my avcr, such a soldering wiring mess it was. try to see if the connections are snug or maybe one of them is backwards. It happens
SoguRacing is offline   Reply With Quote
