Old 06-04-2008, 07:42 AM   #1
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
Os Giken Super Single (sr)
hey everyone i just purchased a used clutch. got the rebuild kit for it. now im just curious what Throw Out Bearing that is required for the OS Giken super single clutch for the s13 SR20det.
i dont want to ghetto rig it, shits gotta be done right.
just curious is everyone has ever used it, opinions overall and which TOB to use?
thanks in advance.
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 06-04-2008, 07:46 AM   #2
Sileighty_85
Sileighty_85's Avatar
The OS Giken one
http://www.rhdjapan.com/jdm-low/OS-G...e-Bearing-8664
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-04-2008, 07:49 AM   #3
yokotavia
yokotavia's Avatar
im hearing an OEM TOB is recommended.
how do you know i need the OS giken specific bearing?
Old 06-04-2008, 07:51 AM   #4
Sileighty_85
cuz the OS Giken uses a longer collar and the bearing is differnt
I have a twin plate so I know
I posted a pic of the difference between OEM and The OS Giken one in another thread
後輪駆動車1番
1986 SR86 - 200ish
Old 06-04-2008, 07:53 AM   #5
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
Yep, with most plate clutches like that, you need the manufacturer's TOB. I have an ORC Single, and it uses the ORC bearing, and it's quite different from the OEM one.
upSLIDEdown is offline   Reply With Quote
Old 06-04-2008, 07:54 AM   #6
yokotavia
yokotavia's Avatar
alright. but, what if my super single is different.
im looking for people that have used this exact clutch before.
twin plate is a bit different from single
Old 06-04-2008, 07:59 AM   #7
Sileighty_85
well it more than likely thinner
regardless OEM will not work properly for the OSGiken
I did an Install on a twin plate using the OEM Collar but Used the OS Giken Bearing, The clutch did not disengage completely even with ajusting the MC rod, becuase the collar was differnt
so with a Single more than likely it wont disengage at all
You have to use the OS Giken Bearing the contact point for the Pressure plate smaller
So if you use a OEM bearing you will more than like break the PP Fingers or the collar
後輪駆動車1番
1986 SR86 - 200ish
Old 06-04-2008, 08:05 AM   #8
yokotavia
yokotavia's Avatar
domo.(thanks)
ill research some more and see how it goes.
thanks for the 1 minute man response too
Old 06-04-2008, 08:09 AM   #9
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
http://osgiken.net/products/racingmultiplate.html
os says that you can run a nissan tob.
it comes off an early nissan truck.
here is the part number.
30502-14601
here is the p/n for the sleeve.
30501-N1600
lok is offline   Reply With Quote
Old 06-04-2008, 08:13 AM   #10
Sileighty_85
30502-14601
30501-N1600
Well there ya go
I was reffering to not being able to use the OEM SR
後輪駆動車1番
1986 SR86 - 200ish
Old 06-04-2008, 08:18 AM   #11
yokotavia
yokotavia's Avatar
i love you.
msglength
Old 06-04-2008, 02:19 PM   #12
vespaman
vespaman's Avatar
Trader Rating: (64)
vespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to beholdvespaman is a splendid one to behold
Feedback Score: 64 reviews
okay that's the same problem i have when i bought my blitz active clutch and the problem solve by using TOB from datsun 510
vespaman is offline   Reply With Quote
Old 06-04-2008, 06:16 PM   #13
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
TOB is usually thinner on the single plates. Twins, you replace the carrier too...
CLICK HERE!!!
Old 11-02-2015, 07:33 AM   #14
Jorgs_7
Jorgs_7's Avatar
Jorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really niceJorgs_7 is just really nice
Extreme bump from the dead.
Jorgs_7 is offline   Reply With Quote
Old 11-02-2015, 07:42 AM   #15
Jorgs_7
Jorgs_7's Avatar
Need clarification:
I have a Cusco Super single (OS giken? Same thing?)
Need the throw out bearing for it.
Any help?
