Retired General
Are there any ways to get a quicker launch in an auto 240?
Yes, i know i need to do the 5-speed swap (i really really want to), but i just cant afford it right now.....i just bought an exhaust. So is there anything i can do? By the way, this is for LEGAL racing (RaceLegal.com 1/8 mile races at Qualcomm Stadium in San Diego, CA). Can i hang at all? Thanks. p.s. i have an S14 |
Retired General
no luck with the search. I saw something about removing some wire to make the car shift harder, but thats about it. I'm not looking to shift harder. I'm looking for ways to launch faster from a stand still. Sorry to everybody about any confusion. Thanks.
![]() Join Date: Jul 2001
Hold Brake with left foot then press the gas reving it as high as it can go before breaking free of the brakes, when the light turns green (actually let go at the last yellow bulb) let go of the brake and floor it. I also use to shift for my old car (1->2->D) But thats cause it didn't shift when i wanted it to, your car maybe different. Those are the main things I have learned going to a drag strip with a auto.
#5 |
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/withstupid.gif" border="0" valign="absmiddle" alt=':withstupid:'>
91 Nissan Silvia SR20DET Sr20 down pipe Blitz boost controller HKS Intake HKS Hi Power Exhaust Straight pipe Razo turbo timer Prof blow off valve |
#6 |
Retired General
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (ca18guy @ Dec. 08 2002,07:14)</td></tr><tr><td id="QUOTE">Hold Brake with left foot then press the gas reving it as high as it can go before breaking free of the brakes, when the light turns green (actually let go at the last yellow bulb) let go of the brake and floor it.</td></tr></table><span id='postcolor'>
i understand what your saying, but wont this burn up my rear brakes? |
#7 |
I hate you too...
It won't burn out your brakes if you aren't spinning your tires. But, you will need some badass brakes back there. My car tires let go at 2000 rpm. With stock rear brakes, shitty pads, and z-rated tires.
-Jeff
Whatup? |
#8 |
Theres also some clip you can undo which would make the tranny shift much quicker but I dont think its very good for the transmission itself.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess ![]() |
#9 |
I hate you too...
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Ni5mo180SX @ Dec. 08 2002,7:14)</td></tr><tr><td id="QUOTE">Theres also some clip you can undo which would make the tranny shift much quicker but I dont think its very good for the transmission itself.</td></tr></table><span id='postcolor'>
It's on the driver's side fender, right where it bolts to the wheel well. It is the only grey plastic clip there. You can undo it if you want, but I think that it hurts stuff. My tranny kicks hard, and makes metal on metal clangs when it shifts. Just waiting for it to die so I can swap! -Jeff
Whatup? |
#10 |
![]() Join Date: Jun 2001
u can do tha braking technique, but i find i get the best launches when i dont floor the car right away, nissan has a .1 or .5 second pause encoded in the ecu if u floor it, so dont floor it, once ur going u can floor it and that, in my opinion works the best
#11 |
jus curious what are some performance mods u can do to do better at the line, we are talking about an auto here.
VROOOOM PHSSSSSS clunk bang...Dammit! |
#12 |
#13 |
me and my friend both did the 1/8th in his auto se-r. i use brakes + gas then let off brakes to launch(not my car, dont want to break it), he put it in neutral and revved to about4k, and dropped it into D, (neutral drop, bad for tranny). the result was my method had faster reaction time, but slower 60' and eventually slower 1/8th... so faster reation using the delay with neutral drop he wouldve beaten my reation and my time making it the fastest method. i dont recommend cuz it hurts tranny and no good... but its def the fastest way i know of. i even tried it once in a 4cyl plymouth voyager, and spun front right tire on dry street. ouch
cmon, i just need to borrow $4K!!! |
#14 |
![]() Join Date: Feb 2002
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Ni5mo180SX @ Dec. 07 2002,7:14)</td></tr><tr><td id="QUOTE">Theres also some clip you can undo which would make the tranny shift much quicker but I dont think its very good for the transmission itself.</td></tr></table><span id='postcolor'>
Don't do that...you'll be hurting your tranny and dealing with the dread check engine light for awhile. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'> The best way to launch is the brake throttle technique that someone mentioned. I tried it before and it's not that bad....but I still rather have a 5spd....doing 120 in fourth gear is no fun. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sneaky.gif" border="0" valign="absmiddle" alt=' ![]()
Goals are dreams with a deadline. L.H.O.O.Q. |
