06-19-2008, 04:13 PM | #1 |
T28 vs. T25
hey everyone i've had my T/28 on my S13 Sr20det for about 2 months now its a ball bearing from the zenki s14 blacktop i've searched didn't really find
anything... i dont have 550cc injectors,z32 maf, or tuned should i go back to my T/25 since i juss daily drive??? good advice would be nice thanks everyone... o and one more question a T/28 at 8psi and a T/25 at 8 psi do they run the same power??? i would figure the bigger turbo runs more since its bigger... Last edited by JRwerks; 06-19-2008 at 04:14 PM.. Reason: add |
06-19-2008, 04:21 PM | #4 |
It's actually called a GT2570...but since S14s don't have bigger injectors you'll be safe on stock boost. S14s obviously have different MAFs and ECUs though.
Instagram - SJKnoop |
06-19-2008, 04:33 PM | #5 |
Maybe this will help
http://www.zilvia.net/f/showthread.p...36#post2068836 your probably not at this same power level I have alot of mods done But I dyno'd My T-28 on stock S13 SR ECU, Injectors and MAF and it was leaning out after .8 Bar
06-19-2008, 04:36 PM | #6 | |
to the original poster, you needn't go through the trouble of swapping your smaller turbo back in, as there wouldn't be much point to it. the t28 will make more power and spool just as fast (ball bearings are wonderful). your stock injectors are the same size as the s14's stock injectors, and if you are still keeping it on stock boost, then you definitely aren't maxing out your injectors or maf. I would imagine the ecu should be able to adjust for it pretty easily too, but just to be safe, you should put a wideband in the car to monitor this (make sure your afr's are at least under 12.5, and preferably in the 11's). also, if you are still on stock 240sx fuel pump, it'd be a good idea to go ahead and change that out for a bigger one.
06-19-2008, 04:56 PM | #7 | |||
The link i posted is my Dyno run with an S14 T-28 BB Turbo and @ .8Bar on 370cc inj. I was leaning out in the top end, so I dont think Nissan would run 370's with a T-28. Also when I had my PFC hooked up for Testing/ information purposes,Injector Duty Cycle was 90-100% at .9 Bar Quote:
so A T-28 @ 11psi will push more air than a T-25 at 11psi, thus creating more power So a T-28 at 10psi is equaled to a T-25 at 14 psi...(Not exactly accurate but just to give you an idea)
06-19-2008, 05:00 PM | #8 |
is there anything wrong with your setup?
get a safc, 480cc injectors, and or wideband.
fS! vlsd ! slim fans ! hid kits ! lug nuts ! http://www.zilvia.net/f/search.php?d...earchuser=bo2o ^^^click^^^ |
06-19-2008, 05:21 PM | #9 |
does anyone have a pic of the t25 and the t28 right next to eachother to compare them in size???
im just wondering how much the size difference is.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
06-19-2008, 05:26 PM | #10 |
Its a Pulsar GTI-R turbo Basically same thing, give ya an idea
S14 Housing just looks differnt
06-19-2008, 05:27 PM | #11 | |
i will look at it when i get home at 2am. damn night job.
06-19-2008, 05:48 PM | #12 |
thew t/28 iss wayyy bettter
NEED S14 KOUKI VALANCES, S14 NAVAN SIDE SKIRTS, S14 KOUKI OEM JDM LIP HIT ME UP!! Last edited by gunmetalr32; 06-19-2008 at 05:49 PM.. Reason: ooOps |
06-19-2008, 05:50 PM | #13 |
nothing is wrong with my car juss dont wanna risk anything...
im running a good amount of mods also: dc turbo manifold megan outlet pipe 3in downpipe/cat delete pipe 3in full exhaust hks intake and im runnning 10psi on the t28 right now... anything wrong with that??? |
06-19-2008, 05:58 PM | #14 | |
If you look at my dyno sheet you will see that at 11psi it will run lean (Too much air, not enough fuel. Which is bad) So you really need to get some 550cc's and A Tune
後輪駆動車1番 1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit Last edited by Sileighty_85; 06-19-2008 at 06:32 PM.. |
06-19-2008, 06:42 PM | #16 | |
oh dont forget the Z32 MAF
06-19-2008, 10:31 PM | #17 |
Ok, is it just me. Or do these turbos look different??? The one on the right looks slightly larger.
LSX Kouki Project, swap completed in Dec 09 |
06-19-2008, 10:34 PM | #18 | |
As stated above The right is a T-28 Non-BB off a RNN14 Pulsar GTI-R and the left is a Stock S13 T-25
06-19-2008, 10:38 PM | #19 |
Ok, I misunderstood what you where saying at first. I thought pic was suppost to be the T28 bb and the Pulsar GTI-R.
06-21-2008, 01:43 AM | #20 | |
And you're right about your duty cycle being so high as well, even on lower boost (which is why I never ran more than 11psi on my stock injectors). Though I think the stock injectors tend to flow slightly more than they are rated at as well, since when I had a set cleaned and flow tested, they were all rated at around 410 (though I'm not sure on the cleaning process, they might have been opened up slightly on a lathe to yield this flow rate) btw, for anyone who is interested, I have an s14 ball-bearing t28 for sale. go here for more info http://www.zilvia.net/f/showthread.php?t=197102
06-21-2008, 08:54 PM | #21 |
Yep both s13 and s14 injector size is the same. On my s14 blacktop I was running 370cc stock injectors and running 15lbs on high boost 10 on low and 7ish without the controller on. My 90 is currently under the knife and getting a Redtop done and i'll be running my T28 with front mount and turbo outlet pipe downpipe and exhaust with no moddification to boost. This car will be my Daily Driver. The guy that's doing my build told me that i would be fine at stock boost levels but if I wanted to up the boost i would need to get a boost controller and something like a Apexi AFC Neo to adjust the A/F ratio. |
06-27-2008, 03:36 PM | #24 |
From the compressor map on the s14 t28, it looks as though 16psi is closer to the point where efficiency really drops off quite a bit. Though you will still make a little bit more power on 18psi than on 16. This was confirmed at the track when i trapped 110mph on 16psi and then 111mph on 18psi (it was a hot day, good traction but low trap speeds: for reference, 13.5psi trapped 106).
06-27-2008, 05:47 PM | #25 |
ok ok ok...
so you can run a t28 @ 7psi on a stock s13 redtop no problem? i have no idea what the bar to psi conversion is. .8 bar is what psi? edit: k, .8 bar is 11psi. dont flame me. im sick in bed. too lazy to search. |
06-28-2008, 12:27 PM | #29 |
the stock wg actuators are set to 8psi on the s14 t28. that would probably be fine on a stock redtop sr20, but i highly recommend that anyone who mods a boosted or nitrous car have a wideband inside to make sure their afr's are safe. Just as a reference, whenever I boosted up my stock t28 to 11psi (the max i was willing to run on my stock injectors and maf) I increased fuel pressure to about 44psi base in order to get my afr's into the 11's and ensure everything would be safe (on the other hand though, I have a friend who boosted his stock t28 up to 14psi on stock injectors and maf with no tuning and afaik it could still be running).
