Old 06-20-2008, 01:10 PM   #1
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
Altima Fans killed my Relays
Here it is:
I am running dual altima fans on a s14, wired to a Greddy MSS. I have both fans wired to run on High each fan is wired to its own 30A relay and 30A fuse. Both relays are wired to trigger on a ground signal sent out by the MSS. Recently only one of my fans turn on effectively. The other never triggers, and the reason is due to burnt out relays. I have replaced the relay twice now. Since these buggers are not cheap to replace. I would like to seek you advice on how I should go about to debug my issue.
#1 I dont know why my relays keep burning out? Could it be excessive current draw?
#2 Could it be that my fans are drawing more than the relay is rated for? 30A? (but than my fuse is also 30A, I would suspect my fuse would blow first).
#3 I have visibly checked for shorts, and cannot locate any.
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
