![]() Join Date: Feb 2002
Is it possible to buy an oil relocation kit, and run the turbo oil lines off of that instead of tapping the oil pan? In theory, could I run the turbo feed line straight from the relocation kit, return line to the oil cooler, and then back to the relocation kit? A buddy at a local shop recommended this, but I don't know if it would be reliable, or a good approach. Thanks in advance.
"Pure adrenaline attached to a license plate. Isn't it time to experience one yourself?" -Dan Gurney Turbo for Sale |
![]() Join Date: Apr 2002
The point of dumping the return oil back into the pan is to allow it to "de-foam" as it gets really bubbly from the spinning turbo (at least this is what I've read...as I can't see inside the motor). I would say this is not the best thing to put through and oil cooler. But you *can* tap off the sender for the supply line <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt='
![]() Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
![]() Join Date: Nov 2001
The oil needs to drain out of the turbo with gravity, so you won't be able to get it to flow through the oil cooler. I drilled out and tapped my dipstick hole, so that's how I did it with out welding on the oil pan, but then you have to figure out another way to check your oil level :-)
I agree with grumpy
Adam '89 coupe KA24DE+T 14.1 @ 104 MPH '88 Celica All-Trac turbo stock, but no more ecu codes!! |
#5 |
Well alright. Thanks for the responses, and I'll pass on the kit. I didn't think it would be a good way to do it, or else it would have been done a lot more. Thanks again.
