Old 12-14-2002, 07:57 PM   #1
A51_RPS13
A51_RPS13 is an unknown quantity at this point
Ok, I'm probably gonna get flamed for this, but o well. I have ordered R32 GT-S Brakes. I'm having these re-drilled for a 4 lug application. Have to get new brakes. Getting only the fronts for now.
But my question is this. What else will I need besides the steel braided conversion lines? And if I do decied later on to do the rears? Will i need some special thing so that I can use my e-brake? Thanks everyone, your help is appreciated.
www.Area51Fab.com
NSB Project
A51_RPS13 is offline   Reply With Quote
Old 12-15-2002, 01:44 AM   #2
AKADriver
AKADriver's Avatar
No flames, though they are basically the same as Z32 brakes, so if you paid more than you'd pay for Z32 brakes, you got hosed <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
Conversion lines should be all you need. &nbsp;Um, and new fluid, and pads.
The R32 GTS-t has the same type of rear brake as the Z32, but considering it has a longer wheelbase, the R32 GTS-t handbrake cables might reach.
Old 12-15-2002, 02:00 AM   #3
adey
adey's Avatar
adey is an unknown quantity at this point
unless they use the same rotors/pads as the Z32, you will also have a v. hard time finding rotors and pads. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> &nbsp;Good luck... you'll probably end up spending a shottyload on rotors, unless a US model has the same rotors as the GT-S... &nbsp;is it even the GTS-T, or just a GT-S? ... If it's the non-turbo R32, you may even have smaller brakes than a Z32.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 12-15-2002, 02:01 AM   #4
Dousan_PG
Dousan_PG's Avatar
werd. if it was GTR R32 i can see. they are built differently the z32, wont fade at all. better air flow/cooling design. at least that's what i've heard on them..
anyways,
ebrake you'll need a kit, i believe projectsilvia is releasing one soon. r32 and z32 use same sort of setups.
Aaron
Pink GodziRa
