Old 12-11-2001, 07:22 PM   #1
kustom
kustom is an unknown quantity at this point
Ok, i guess i start a lot of these but:
I would prefer not to spend a grand on a FMIC plus attract attention  so.....
if i use the stock SR intercooler (side mount) then how much boost can i realistically push? Some have said 14psi others 8 so let er rip!
kustom is offline   Reply With Quote
Old 12-11-2001, 07:23 PM   #2
mistert
Pearl White Mike
mistert is an unknown quantity at this point
Send a message via ICQ to mistert Send a message via AIM to mistert
around 14, thats also the limit on the stock turbo for an s13, and the headgasket as well
mistert is offline   Reply With Quote
Old 12-11-2001, 07:27 PM   #3
kustom
why do people use the front mounts if it will go to14? I mean how many people are really pushing more?  What does 14psi make anywho, 250Hp?
Old 12-11-2001, 07:35 PM   #4
MattS14
MattS14 is an unknown quantity at this point
i think many people go to the front mount when they do the swap for a few reasons....
1: In there mind it gives them that little extra protection againt detonation even on stock boost.
2: It is alot easier to install when the engine is out.
3: It looks sweet
4: personal prefrence
MattS14 is offline   Reply With Quote
Old 12-11-2001, 07:35 PM   #5
mistert
Pearl White Mike
i understand 14psi will make in the 260-285 range. i dunno i guess alot of people just want to look cool, or else they think its neccessary when it really isnt. of course, having a thicker intercooler will cool the charge better, and possibly afford better HP, if im not mistaken, at high boost levels.
Old 12-11-2001, 07:40 PM   #6
kustom
so how many people have seen the SR running decent numbers on the stock intercooler?
You guys are making me feel a lot better! Thinking of dropping 1k on it makes me queezy!
Old 12-11-2001, 08:02 PM   #7
Sway500
Sway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to allSway500 is a name known to all
people get front mounts because it has higher cooling effieciency. Which equals more power.  You know the denser the air  the more power.
Sway500 is offline   Reply With Quote
Old 12-11-2001, 08:03 PM   #8
socom1
socom1 is an unknown quantity at this point
Do you guy's even know what an intercooler does? An intercooler does just that, it COOLS the air going INTO the engine. The reason for a FMIC is simple and has nothing to do with how much boost you can run. The FMIC is larger than stock "some by up to 150%" and is mounted in front of the block. The stock intercooler is side mount and as such will not get as much air flowing over it. The addition of a FMIC can add from 15-150+hp "note that the 150+ is if you are running considerable boost through a top notch turbo". This hp gain comes not from increased boost but from the air being cooler "read: more dense" as it goes into the engine.
socom1 is offline   Reply With Quote
Old 12-11-2001, 08:04 PM   #9
mistert
Pearl White Mike
eys thats true i pointed that out as well, but another reason is also wanting to run more boost. he merely wanted to knwo what you can get out of a stock setup though
Old 12-11-2001, 08:12 PM   #10
kustom
right, just the stock intercooler. I understand what an intercooler does and how it works (they just happened to cover that &nbsp;subject in my 5 yrs of mechanical engineering <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> ). I could list a 100 parts that would improve the car but just want to know what my limitations are on stock internals + decent clutch and STOCK intercooler.
Old 12-11-2001, 08:14 PM   #11
socom1
A stock setup is only limited by the turbo. After about 1bar &quot;14psi&quot; the heat that the turbo generates causes a LOSS in power. A bigger intercooler will not help this. As far as the SMIC itself, there are guys with better turbos running 20-25psi through it with no problem. On a side note, if you drift, retaining your side mount can be a good idea. A SMIC is much less likely to get damaged by rocks and other debris than a FMIC.
Old 12-11-2001, 08:17 PM   #12
kustom
so what you're saying is that the stock smic will be sufficient for my days with the stock turbo? What setup are you using?
Old 12-11-2001, 08:23 PM   #13
socom1
It is not in yet but here you go:
SR20DET blacktop &quot;180sx&quot;
Trust FMIC
550cc injectors
300zx fuel pump
Greddy T-3 bb turbo &quot;maybe a ceramic BB&quot;
APEXi 3.8&quot; GT downpipe
APEXi 3.8&quot; GT exuast
and the much loved K&amp;N filters
Old 12-11-2001, 08:24 PM   #14
socom1
And yes the SMIC will be fine.
Old 12-12-2001, 07:32 AM   #15
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
hmm... I've always heard that the SMIC couldn't take over 10 psi. At that point, it is not longer efficient in cooling the air. Used ones from an s13 motor may also have begun leaking, as they are 10 years old. I've never heard anyone running an SR w/ SMIC at over 10 psi - and not even close to 20!
*edit* reducing &quot;NEVER&quot; to &quot;never&quot; b/c further research showed that there are a few at around 14 psi... looking for an upgrade;) *edit*
(Edited by HippoSleek at 10:33 am on Dec. 12, 2001)
HippoSleek is offline   Reply With Quote
Old 12-12-2001, 10:50 AM   #16
Zenki Two40
Zenki Two40 is an unknown quantity at this point
w/ a stock set up of minor mods, the stock intercooler will be sufficient. why get a big intercooler n have trouble filling it n not maximizing what u got?
Zenki Two40 is offline   Reply With Quote
Old 12-12-2001, 11:30 AM   #17
Guest
Posts: n/a
What's with all the discrepencies? Are people just voicing their &quot;opinions&quot; without having done it? I mean if someone says &quot;yeah, 14 psi&quot; then we assume that they've done it or seen it done. That being the case how can someone argue?
Old 12-12-2001, 12:28 PM   #18
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from Kustom on 9:30 am on Dec. 12, 2001
What's with all the discrepencies? Are people just voicing their &quot;opinions&quot; without having done it? I mean if someone says &quot;yeah, 14 psi&quot; then we assume that they've done it or seen it done. That being the case how can someone argue?</td></tr></table><span id='postcolor'>
Haven't done it, but here are my sources:
http://forums.freshalloy.com/cgi-bin....=000499
<a href="http://forums.freshalloy.com/cgi-bin/ultimatebb.cgi?ubb=get_topic&f=9&t=005751
Both" target="_blank">http://forums.freshalloy.com/cgi-bin....
Both</a> Asad and Mark are LONG time 240 veterans and I, personally, trust their opinions over others. &nbsp;I've seen the same thing elsewhere too, however. &nbsp;The general impression I got was that above about 10psi, the stock t25 started creating too much heat (b/c it is undersized). &nbsp;By 14 psi, it renders the SMIC ineffective.
Old 12-12-2001, 01:08 PM   #19
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
U could also get a IN from a 87-90 Turbo Supra, its a side mount also, way better cooling, will need to make a few custom pipes.....well worth it, if you don't want to spend the $900-1200 for a FMIC
Kid Zelda is offline   Reply With Quote
Old 12-12-2001, 01:21 PM   #20
socom1
You are right Hippo but if you look at my post I said that the SMIC would work at the higher boost level with a BIGGER TURBO.
Old 12-12-2001, 02:31 PM   #21
KoukiS14
KoukiS14's Avatar
KoukiS14 is an unknown quantity at this point
Send a message via ICQ to KoukiS14 Send a message via AIM to KoukiS14 Send a message via Yahoo to KoukiS14
I personally prefer a SMIC. . &nbsp;Just for looks, I don't want a large oversized intercooler... for my application, it would be a waste of time and money, and limit the cooling ability of my radiator.. With that being said. . I understand that there are thicker, higher capacity SMIC upgrades available for many cars, &nbsp;such as 300zx... &nbsp;Is there one for Silvia?
-Rob
KoukiS14 is offline   Reply With Quote
Old 12-12-2001, 08:39 PM   #22
SpoiledBoi
SpoiledBoi is an unknown quantity at this point
Personal observation-Audi A4 1.8t guys cut the underside of the wheel housing cover(i dunno wat its called, i forgot) (they have SideMountIntercoolers too) and they get a noticable difference in, duh, throttle response, and they also know they have gotten more torque for sure.....i havent been on in a while but i dont know of anyone dynoin to make sure i can bacl that up.
SpoiledBoi is offline   Reply With Quote
