Old 07-03-2008, 10:19 PM   #1
Jonnyblaze
Jonnyblaze's Avatar
Jonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymoreJonnyblaze is not welcome here anymore
wierd idle problem.. please help
hey guys, i have a 91 s13 with a stock ka24de and its got a really wired problem. the car wont idle at all.. itll just stall out and die. i have to keep hitting the gas to keep it running and even then its really sluggish. the thing is, if i unplag the MAF it will idle just fine on its own (although it is very rough). it is rev limited to 2.5k though without the MAF.. whats the deal? if the MAF is plugged in it will drive just fine it just wont idle
can anybody help me out?
Jonnyblaze is offline   Reply With Quote
Old 07-03-2008, 11:27 PM   #2
just1pepsi
just1pepsi's Avatar
just1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfectionjust1pepsi is close to perfection
Send a message via MSN to just1pepsi
First, Check for Vaccume leaks. Make sure all the plugs are in good shape and the plugs are gapped correctly.
just1pepsi is offline   Reply With Quote
Old 07-04-2008, 12:11 AM   #3
Clowny
Clowny's Avatar
Clowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to beholdClowny is a splendid one to behold
Send a message via AIM to Clowny Send a message via Yahoo to Clowny
the rough but stable idle and 2.5k rev limiter is because of the ecu. it isnt recieving a signal from the maf and goes into limp home mode or safe mode as some call it. that way, should your maf or some other sensor die when you are away from home, it will allow you to still drive the car home. as for the idle issue, sounds to me like your maf is dead. hope it helps.
Clowny is offline   Reply With Quote
Old 07-04-2008, 09:58 AM   #4
Jonnyblaze
Jonnyblaze's Avatar
i just bought a new ecu on ebay for $10.. gonna search for a new MAF.. you think this will solve the problem?
Old 07-04-2008, 11:24 AM   #5
littlekids13
littlekids13 is an unknown quantity at this point
try cleaning the iacv i think thats what its called it helped for me just spay a bunch of carb cleaner in there and let it chill for like ten mins your car will be hard to start but just keep pumping the gas it should go
littlekids13 is offline   Reply With Quote
Old 07-04-2008, 04:32 PM   #6
Jonnyblaze
Jonnyblaze's Avatar
already cleaned it..
Old 07-05-2008, 06:05 PM   #7
Jonnyblaze
Jonnyblaze's Avatar
nobody else?
Old 07-05-2008, 06:23 PM   #8
lflkajfj12123
check your tb might not be opened enough at idle
bad MAF is possible too
edit: 2000 post
