Driveshaft Problem
I am wondering if an 1 piece STEEL driveshaft is worth the upgrade? I am doing an auto to 5 speed swap. Is there really a BIG difference? I read thru some threads all I know is that the engine revs faster and faster throttle response, but is it A LOT faster? This will be installed in a KA.
![]() Join Date: Oct 2003
YES! I would definitely get one. The biggest difference is the weight, but you also have to think of the extra play in the joints and the fact that there is a damper in the middle that can wear out over the years. Plus since youre already under there, might as well change it once instead of twice if you have the money.
fixafixa ![]() |
![]() Join Date: Jul 2008
tell you the truth tho i ended up buying a 1pc aluminum during my sr20/auto-manual swap...so i shouldnt speak hahaha, but like trickz said it can be a good investment for the future
#5 | |
![]() Join Date: Apr 2004
What do you value? Tell me what you value and I'll tell you if it's worth the cost to get the benefits. Different compared to what? Stock? Aluminium? Carbon fibre? I assume you're comparing to stock. For a perfect new stock propeller shaft, the difference is significant. Less lag. Less vibration. For a worn out propeller shaft, which you will probably get if you buy used, there is no comparison. The steel 1piece is much better. The response is faster because energy isn't wasted twisting the 2piece shaft. What do you think is a lot? Someone should install a shaft sensor on the output shaft of the gearbox and one on the input of the diff. Then datalog and compare the lag between the two sensors for a 1piece vs. a 2piece. |
#6 |
Yes, I am comparing to stock. Stock vs. Steel. What mean by faster is faster response. Does it have to be Driveshaft shop driveshaft in order to be a quality shaft? How about other shafts like R&D Factory which I look through.
#7 | |
I *heart* DSS. |
#9 |
g6civicx-you said there is "less lag and less vibration"
Wouldn't a 1pc. driveshaft create more vibration, because you no longer can absorb vibration. Would a 1pc. driveshaft be bad for a DD? Is it bearable? I just want to know what I am getting into. |
#10 |
![]() Join Date: Sep 2006
Didnt finish reading the thread.
But when that carrier bearing wears out, Its like $100 dollars under the cost of a one piece steel shaft. So you might as well do it if you can afford it. |
#11 |
kouki man
![]() Join Date: Apr 2006
Trader Rating: (36)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 36 reviews
i have a 1 piece aluminum driveshaft from DSS. i fucking love the response. LOL
i do have vibrations because i havent replaced any motor mounts i got =) hence i have 250k on my car original everything. hehehe |
#12 | |
With a 2 piece, vibration is transferred to the carrier support and the chassis. I have driven over 3+ years on my 1pc with SR and V8. There is no problem for me. |
#13 |
Check out the link below, we have unbeatable prices on Driveshaft Shop Driveshafts.
http://zilvia.net/f/advertiser-speci...ml#post2121657 Pm me or e-mail me at [email protected] if you have any questions. Iggy |
