Old 08-31-2008, 07:57 PM   #1
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
Removing aftermarket steering wheel
OK heres the scoop, i need to fix me horn and i wanna do it right. I have a steering wheel puller and it aint ganna do it, im going tommorro to get a pulley puller instead.But if that dont work does anyone have any ideas? or does anyone know what type of pulley pullers work best.? im prolly ganna end up with the 3 offset slots type.(donnu what its really called) But i have seen many types... any input would be great, only asking for help because this REALLY pisssed me off! simple right?-false.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 08-31-2008, 08:13 PM   #2
spoolandslide
Location: lost in a bump splice in the fabric of our clockwork
spoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfectionspoolandslide is close to perfection
just sit in your drivers seat and take the 19mm steering wheel nut off. grab the wheel at 10 and t2, push up with your knees at 5 and 7 and jiggle it till it comes off
spoolandslide is offline   Reply With Quote
Old 08-31-2008, 08:24 PM   #3
blackrms13
blackrms13's Avatar
loosen the nut but dont take it off completely, just have your hand at 3 and 9 position and rock back n forth until the wheel comes loose
but for a aftermarket wheel, u can probably just use the hex key and get the wheel off and leaving the hub on
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 08-31-2008, 08:24 PM   #4
GSXRJJordan
GSXRJJordan's Avatar
^^^ That's not a bad plan. The pulley puller most likely won't work (at least I haven't seen one that works). Sucks you didn't do it right the first time... I'm guessing you have to take the hub off because you didn't connect the one wire that goes to the horn?
Old 08-31-2008, 08:28 PM   #5
TUBE
TUBE's Avatar
TUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of lightTUBE is a glorious beacon of light
Send a message via AIM to TUBE
240SX Steering Wheel Swap
All the info you need to take it off.
TUBE is offline   Reply With Quote
Old 08-31-2008, 08:31 PM   #6
s13dan
s13dan's Avatar
^said proper... Yea i was in the parking lot of the parts store because i couldnt afford the deposit, so i rushed it... DOH! The 19mm is off and i need to pull the hub so i can find the one horn wire.So ill do some violent shaking!
Old 08-31-2008, 09:04 PM   #7
s13dan
s13dan's Avatar
OK thats not ganna do it, im a decently stong person but it wont budge. I understand leaving the nut on, if that thing did come of it would knock the shit outa me. Its still on, im just afraid the hub will be bent be the puller.
Old 08-31-2008, 09:10 PM   #8
GSXRJJordan
It's not so much pulling straight back (you'll never get it off), but pushing on one side, pulling the other. You're trying to "bend" it off the spline. If your hub is as shitty quality as mine is, I'd be afraid of what a pulley puller would do to it also lol.
Old 08-31-2008, 10:14 PM   #9
500Coupe
500Coupe's Avatar
500Coupe is an unknown quantity at this point
Have you tried a 3 jaw puller?
Build Blog
500Coupe is offline   Reply With Quote
Old 08-31-2008, 10:51 PM   #10
240=180
240=180's Avatar
240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about
lol.....
step 1- take off nut and leave wheel on hub
step 2- take key out of ignition and lock steering
step 3- forcefully turn wheel left and right while pulling back
wheel should come off like nothing.... mine came off within a few seconds using that method
240=180 is offline   Reply With Quote
Old 09-01-2008, 12:16 AM   #11
projectRDM
projectRDM's Avatar
I've pulled over a hundred wheels by now and never used a puller. Just do as suggested, 'rock' the wheel off the splines by shifting it side to side and up/down.
FORMERLY R240NA
Old 09-01-2008, 12:56 AM   #12
DataXUnknown
Trader Rating: (30)
DataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfectionDataXUnknown is close to perfection
Feedback Score: 30 reviews
Don't be scared to break a sweat. Work that shit. It may take anywhere from 5-20minutes of jiggling but it will come off.
DataXUnknown is offline   Reply With Quote
Old 09-01-2008, 06:25 AM   #13
g6civcx
g6civcx's Avatar
The most I've done was used a rubber mallet and tap the wheel gently. Otherwise hitting the circumference of the wheel with my palm has always worked.
Old 09-01-2008, 06:41 AM   #14
ZX88
ZX88's Avatar
i use the palm trick works after like 10 min but it works.
Old 09-01-2008, 11:45 AM   #15
!Zar!
!Zar!'s Avatar
Yeah, I've removed countless wheels and hubs. Just unscrew the 19mm a little bit but not all the way and then rock the wheel as you pull with a few jolts.
What people mess up on is tightening the 19mm too much.
You're only supposed to torque it down to like 20ftlbs.
Old 09-01-2008, 05:30 PM   #16
g6civcx
g6civcx's Avatar
Close. 22-29 ft-lbs as per the FSM.
Old 09-02-2008, 07:35 AM   #17
initial D
initial D's Avatar
initial D is an unknown quantity at this point
what about the little screw behind the wheel under the steering column covers?
initial D is offline   Reply With Quote
Old 09-02-2008, 11:01 AM   #18
s13dan
s13dan's Avatar
For some of you that missed it, its already after market. I have pulled the stock unit a long time ago. And I got it off, i used a pulley puller, its was 12$. The 3 jaw type.Then i sodered the horn wire to the metal ring in the hub. Oh yea,I havent had power steering for a while so thats prolly why it was such a biatch, pwr steering is next to fix.Thanx for all the input, ill remember those methods next time, or if a friend has the same prob.
