Old 09-02-2008, 03:24 PM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Aftermarket SR dump pipe. CHEAP.
Unknown brand dump pipe for SR. It fits a little tight going onto the turbo (T28), and I had to hammer it a little on one side to clear the transmission, but it works fine. Plenty of cross-section for great flow, even with the minor hammering.
Most aftermarket elbows have one of the top holes slotted to fit T25/28, this one does not which is why it's tight going on. It goes on fine; a couple minutes with a Dremel and it would be easier.
Skinny O2 bung (M12 x 1.25).
You can see where it was hammered a little on the right side, in this pic:
Lots of flow:
$40 shipped. If you're local to Virginia Beach, cheaper.
PM me, I need shit gone.
My seller review thread
SHIFT_*grind* is offline
dump pipe, o2 housing, turbo elbow
