Old 09-18-2008, 03:05 PM   #1
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
Weird whining sound power steering?belts?
this sound started up 2 days ago.
it whines at idle, rev, in gear, out of gear
moving the steering wheel does not change the pitch of the sound
the sound is coming more in the general direction of the ps pump
theres also a "chinging" sound coming from the front of the motor as well, the crank pully wobbles a tiny bit. this sound started about a week ago
ive searched, found a few threads, none with definate answers,
heres a vid
YouTube - weird sound
ILoveJDM is offline   Reply With Quote
Old 09-19-2008, 12:13 AM   #2
ILoveJDM
found out what it was for anyone needing this info in the future.
my a/c doesnt work, so i decided to cut the belt off. whining and chinging went away
was either the idler pully or the a/c
Old 09-19-2008, 12:24 AM   #3
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
good for you!
Might want to get that crank pulley fixed... trust me.
SexPanda is offline   Reply With Quote
Old 09-19-2008, 12:28 AM   #4
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
Originally Posted by SexPanda View Post
good for you!
Yep, your rotating mass will go to shit.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
