Old 09-28-2008, 06:18 PM   #1
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
boost gauge lit when cars off
I have one of the newer greddy boost gauges.. Installed about 3 months ago. Noticed today this just started happening it stays lit when the cars off.. Why is this happening and why all of a sudden??
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 09-28-2008, 06:21 PM   #2
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
What do you have the illumination hooked up to?
SDS13COUPE is offline   Reply With Quote
Old 09-28-2008, 06:24 PM   #3
niSm095
niSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really niceniSm095 is just really nice
^^ ditto...make sure there's not a problem with your illumination wire/where it's hooked up. Make sure it's hooked to something like an acc. that comes on with the car...headlights...stereo...
niSm095 is offline   Reply With Quote
Old 09-28-2008, 06:26 PM   #4
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
gauge isnt wired correctly...i had the same problem with some BLOX gauges i had (what a waste of money those were)...but check your wiring points...you may have your power source as a direct 12volt...not an ignition made 12volt (basically meaning that electricity only flows when the ignition switch is in the ON position)
Old 09-28-2008, 06:32 PM   #5
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
wire it into your headlight circuit. It might just be on the main 12v source...
renegade_ewok is offline   Reply With Quote
