Old 09-28-2008, 06:21 PM   #1
boycelaforest707
boycelaforest707's Avatar
boycelaforest707 is a well-known jackass
SR SR20 swap, MAFS problems!
Hey everyone! Just swapped my sr20, here is the problem:
It starts and idles, not a very smooth idle... anyway you cannot rev it up or it dies.
What I have done:
Checked ECU, code 12 MAFS
Checked wiring from MAF sensor to ECU
Tried a SOHC MAF
Other stuff:
I have 12v on the black/white stripe wire @ maf, the black ground wire is good all the way back to the ECU, but:
White wire reads 12 volts with key on, ignition off, if I ground the black wire to chassis (in addition to ecu) it drops to around 1 volt.
What should it read? Is my ECU bad?
Thanks guys!
1991 240sx Hatchback 5spd
boycelaforest707 is offline   Reply With Quote
Old 09-28-2008, 07:08 PM   #2
upstate240sx
upstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really nice
any air leaks?
upstate240sx is offline   Reply With Quote
Old 09-28-2008, 08:09 PM   #3
boycelaforest707
Originally Posted by upstate240sx View Post
any air leaks?
Nope, triple checked intercooler piping...
Old 09-28-2008, 08:46 PM   #4
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
check your air filter adapter. It may be blocking the sensor.
Team Pterodactyl
kevtrinh is offline   Reply With Quote
Old 09-28-2008, 08:58 PM   #5
boycelaforest707
I have just the MAF, no airfilter or airfilter adapter.
Old 09-28-2008, 09:01 PM   #6
s14jesse
s14jesse's Avatar
s14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-knowns14jesse is making his/her stupidity well-known
Send a message via AIM to s14jesse
check ur maf wires and to the ecu and if its all good i has to b the timing is bad im pretty sure its ur timing
s14jesse is offline   Reply With Quote
Old 09-28-2008, 09:07 PM   #7
greddyguy
greddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choicesgreddyguy has made poor choices
maf is toast! or could be a funky wiring problem.....those SUCK
greddyguy is offline   Reply With Quote
Old 09-28-2008, 09:41 PM   #8
boycelaforest707
Tried another MAF, wiring was tested back to ecu, try again.
Old 09-28-2008, 09:42 PM   #9
boycelaforest707
Maf wires tested back to ecu. I will pull valve cover and inspect the CAS/timing tomorrow, thanks.
