Old 10-06-2008, 03:19 PM   #1
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
fuel guage problem??
ok so i noticed that after yesterdays drift event my gas needle doesnt move. it stayed at a little above half a tank. and it was working perfect before. any ideas? maybe the gas moving inside the tank is a factor?
Krusty_s13 is offline   Reply With Quote
Old 10-06-2008, 03:27 PM   #2
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
Seems to happen alot with 240's....your best bet is to open up the gas tank pull out the filler gauge and see if its stuck.
Maiku240sxS14 is offline   Reply With Quote
Old 10-06-2008, 03:36 PM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
its called owning a 10-19 year old car that has had shitty gas put in it its whole life...deposits build up on the little metallic reading unit attached to the floater and they just tend to wear themselves out
best suggestion i can give to you is go to the junk yard...pull a sending unit from a wrecked 240 and see if it works...i seriously doubt you want to spend the money at the dealership to buy a new one (im guesing they would be around 500-1000 monies)
my 240 has a really bitchy sending unit floater...but ive had that happen in ALL the 240s ive owned...it likes to lose its reading around half a tank and just moves up and down between half full and completely empty as im driving around...works fine up until that point (like if i have a full tank of gas)
but yah...old car = shit likes to stop working because its OLD!!!!
Old 10-06-2008, 03:49 PM   #4
Krusty_s13
Krusty_s13's Avatar
yea i remember i looked into the fuel sending unit and with my friends mechanic discount it was around $300+. ill check it out. thanks
Old 10-09-2008, 11:10 PM   #5
sb253
sb253's Avatar
sb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud ofsb253 has much to be proud of
Send a message via AIM to sb253
OK so I did a search and instead of starting a new thread Im just gonna ask here:
So ive noticed that on my 95 the gas gauge fluctuates almost a quarter tank. Especially when I take long on/off ramps. Sometimes it will rise back up but sometimes it will drop and stay. My friend's guage in his 13 stop working then start back up again but mine just runs all over the place.
Anyone else had a problem like mine? Is my problem the same faulty component as stated above?
thanks
sb253 is offline   Reply With Quote
Old 10-10-2008, 01:40 PM   #6
sb253
sb253's Avatar
sweet thanks
Old 10-10-2008, 01:53 PM   #7
mestizo
mestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the roughmestizo is a jewel in the rough
There has been a thread about this before... I can't speak on the S14 issue cuz they use a different sending unit than the S13. But I do know that the S13 tank has a metal baffle that likes to comes loose, when it does it usually gets stuck under the float arm on the sending unit and causes it to stick or stay in one position. Sometimes it will break the sending unit and in my case it shorted out my fuel pump.
Pop the cover open and take a look inside, should take you about 15 mins.
92 S13 Coupe Track Car
mestizo is offline   Reply With Quote
Old 10-10-2008, 01:55 PM   #8
projectRDM
projectRDM's Avatar
S14s do it too, though not as common, the sending unit falls loose in the tank and floats around.
FORMERLY R240NA
Old 10-10-2008, 01:58 PM   #9
Sileighty_85
Sileighty_85's Avatar
mines similar on my 91
First gauge when full would go past Full and empty was at 1/4 of a tank (Found that out the hard way)
Switched the gauge out with another worked great for a while,
now with a full tanks it stops betwen Full and 3/4
reads 1/2 with 12 gallons but becomes accurate below 1/2 a tank
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-11-2009, 11:35 PM   #10
amdnivram
amdnivram's Avatar
amdnivram is an unknown quantity at this point
Send a message via AIM to amdnivram
i started to hve the same problem a week ago.
amdnivram is offline   Reply With Quote
Old 02-12-2009, 01:49 AM   #11
motegineon
Banned from the Marketplace
motegineon's Avatar
motegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond repute
Send a message via AIM to motegineon Send a message via MSN to motegineon
hmm
mine went out last night while sliding
it was at half a tank and then the next minute it was below it, any suggestions? Ive since driven over 100 miles so its definitely the gauge
motegineon is offline   Reply With Quote
Old 02-15-2009, 06:56 PM   #12
motegineon
motegineon's Avatar
well I took out my fuel pump today and moved the little floater actuator thing back and forth a few time. I reconnected the wires and started the car up and the needle went up to about half a tank, which is about what I was guessing I had so i guess that solved the problem. Just a heads up to those who may wana give that a shot, only took about 20 minutes.
Old 02-15-2009, 07:03 PM   #13
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Its a good idea to remove the sending unit and with some very fine sand paper sand the electrical contacts on the sweeper arm contact thingy, I've done this on just about every nissan I owned and it fixed inaccurracy problems with teh fuel gauge.
