Old 10-07-2008, 04:11 PM   #1
corey240
corey240's Avatar
corey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymorecorey240 is not welcome here anymore
Send a message via AIM to corey240 Send a message via MSN to corey240
SR Hesitation when fans are on
I have this bad hesitation, like the motor doesnt want to go, like somthing is holding it back, until 2400 rpm. Ive checked everything and ecu throws no codes. Now on the way to work my fans shut off. This happewns ometimes because the realy is going bad so I have to pound it and it kicks over.
I noticed the car was running really smooth, and felt a bit faster, ands it pulled harder. So when I kicked the fans over, it hestated again. Then, on the way home, they shut off again. I thought man its running good now wtf. And noticed the temp was creeping up, so I turned them on again, thus producing crap. How would the fans affect my motor so harshly? It has to have somthing to do with it, I just cant figure out how.
Email: [email protected]
corey240 is offline   Reply With Quote
Old 10-07-2008, 04:36 PM   #2
YucA
YucA's Avatar
YucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of lightYucA is a glorious beacon of light
grounding issue? The fans suck a shitload of amperage...
If you have a problem with the relay, i wouldnt be surprised if thats part of the problem...
YucA is offline   Reply With Quote
Old 10-07-2008, 05:23 PM   #3
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
alternator mine does the same thing
Bigsyke is offline   Reply With Quote
Old 10-07-2008, 05:25 PM   #4
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
What fans are you using?
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-07-2008, 05:26 PM   #5
WISH ONE
alt, wiring, battery, poor grounds.
Old 10-07-2008, 06:46 PM   #6
Bigsyke
Bigsyke's Avatar
I think altima fans just do that.
Old 10-07-2008, 07:04 PM   #7
spirit
spirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant futurespirit has a brilliant future
I run altima fans on stock sr alternator. I don't have that problem, but I also run a red top optima battery & upgraded wiring. Tho I also have over 2000watts of audio shit too.
spirit is offline   Reply With Quote
Old 10-07-2008, 07:21 PM   #8
Bigsyke
Bigsyke's Avatar
upgraded wiring in what reguards?
Old 10-07-2008, 07:44 PM   #9
corey240
corey240's Avatar
I have dual flexalites. I also have a ka alternator that i put on like 2 years ago, off a 95-96 ka, so I didnt think it would be that. Although, I wondered that today once the fan thing cought my attention. I am going to go over my wiring, and get my alt tested tomorow. Thos are simple things to check. Any ideas are appreciated, this problem scares me it may turn worse if its not fixed.
Old 10-07-2008, 07:45 PM   #10
spirit
Battery in the trunk.
0 gauge from trunk to front, where all the stock & modified stuff connects to. Used a home depot home wiring block to wire everything up. Kinda ghetto, but real easy to make changes.
0 gauge ground in the trunk area.
Old 10-07-2008, 08:37 PM   #11
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
mine does the same thing also when getting sideways the rpms will jump
like if im drifting around sumthing and keep gettin on an off the gas
the rpms go crazy like from 6 it will go up to 9 i know im not reving that
high i can hear the motor but idk car runs good tho sohc with dual
felx a lite 220 fans
i think it might be the grounds gotta clean them
Red Rocket
apex is offline   Reply With Quote
Old 10-07-2008, 08:50 PM   #12
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
had a similar problem on my SR running the dual flex alite . i upgraded the battery and problem gone . braille 3121 that thing is powerfull ..
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
