Old 10-18-2008, 05:37 PM   #1
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
Need help asap:::vehicle speed sensor:::signal wire
1997 S14 KA(if that matters)
hookin up a greddy turbo timer. i have the ignition harness, so thats done.
now i need to hook it up to the speed signal wire. i found the speed sensor on the tranny.
I have two wires out of the sensor.
-RED
and
-RED w/yellow stripe.
which one is the signal wire???
Marcus is offline   Reply With Quote
Old 10-18-2008, 06:10 PM   #2
xplicit240
xplicit240's Avatar
xplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nicexplicit240 is just really nice
Send a message via AIM to xplicit240
red is usually just constant power. id bet red/yellow. you can also look in the FSM!
xplicit240 is offline   Reply With Quote
Old 10-18-2008, 06:24 PM   #3
spikNspan
spikNspan's Avatar
spikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura aboutspikNspan has a spectacular aura about
Send a message via AIM to spikNspan
you don't have to hook that up for the turbo timer to work, if you already knew this disregard.
spikNspan is offline   Reply With Quote
Old 10-18-2008, 06:41 PM   #4
Marcus
Marcus's Avatar
Trader Rating: (18)
Ok. I hooked up the harness but the car won't start. Why?
Old 10-18-2008, 07:33 PM   #5
Marcus
Marcus's Avatar
Trader Rating: (18)
i checked out the harness that i bought. the ignition harness on the car has six wires. the greddy harness only has 4 prongs. they plug in, but its like there's two missing prongs.
i think thats why. ill ask someone local with a harness to see if i happened to get the wrong one.
Old 10-18-2008, 11:16 PM   #6
projectRDM
projectRDM's Avatar
That's a JDM ignition harness. The plug in harnesses they sell are not made for US cars, we have an extra wire in the switch harness.
The VSS signal wire is yellow/green, found behind the cluster or at the ECU. Same as nearly all Nissans.
FORMERLY R240NA
Old 10-19-2008, 01:34 AM   #7
Marcus
Marcus's Avatar
Trader Rating: (18)
cool. so do i just plug in the harness, then wire the remaining two back together?
Old 10-19-2008, 10:04 AM   #8
projectRDM
projectRDM's Avatar
Yes, or don't even use the harness and just splice in what you need.
FORMERLY R240NA
