Old 11-16-2008, 09:09 PM   #1
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
ka24e problem
Ok so the problem is this, the car will not start. It gets gas and spark. The only thing i did was take the distributer out because it broke. I didnt mess with the timing chain or anything, the only thing i did was replace the distributer. Any ideas?
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 11-16-2008, 09:11 PM   #2
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
you probably fucked up the timing when you replaced the distributor
double check that it's aligned correctly
96Turbo is offline   Reply With Quote
Old 11-16-2008, 09:54 PM   #3
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
yea man check you fsm on how to properly install the distributor
redline racer510 is offline   Reply With Quote
Old 11-16-2008, 09:56 PM   #4
singlecamslam
I'm downloading the FSM right now. I just though that the distributor can go in only one way so it would be alright just to put it back in.
Old 11-17-2008, 04:50 PM   #5
singlecamslam
Alright i read the FSM manual and it sucks. I got it from zeryon or whatever. But from my understanding, do you just put the No.1 piston at TDC and put the distributor pin on the No.1? The distributor goes in only one way because it has a notch on it so i though by just throwing it in there would be fine.
Old 11-19-2008, 03:33 PM   #6
singlecamslam
Problem solved. Apparently there are several different distributor caps that number the firing order differently. Weird.
