Old 02-09-2003, 01:03 AM   #1
fleaf
fleaf is an unknown quantity at this point
Angry my clutch!!.
About a week ago..my clutch started sticking. I thought to myself..."no problem, I'll just bleed the clutch lines and it'll be fine". So I recently bled my clutch lines...but it seems like the problem has worsened. Now when I press on the clutch, there is absolutely NO pressure at all...it feels like it's automatically being pushed in.
Is my clutch going bad? This is my first manual car...I'm going to bleed the clutch lines again tomorrow to see if it doe anything..
Thanks
fleaf is offline   Reply With Quote
Old 02-09-2003, 01:22 AM   #2
adey
adey's Avatar
adey is an unknown quantity at this point
My first inclination is to say "bleed it again" ... because it sounds like that's the problem. I have a new clutch master cylinder sitting on my floor right now waiting to go in in place of my leakey MC... I once lost all my fluid, causing exactly that problem. You can probably still get some pressure out of it by pumping the clutch, but you will have to fill and bleed it at some point.
Good luck!
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-09-2003, 09:35 AM   #3
mrmephistopheles
mrmephistopheles's Avatar
How old is your car? How many miles?
Bleed your clutch again, and if it's to no avail, you may need a new master and/or slave cylinder.
Old 02-09-2003, 09:42 AM   #4
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Definitely sounds like master/slave cylinder. Or maybe you'll be lucky and it will only be the spring on the pedal mechanism.
I remember how much of a PITA it was to drive my car w/ only 1" of clutch pedal movement when my master cylinder went out. I'm glad I won't have to worry about that again!
Lauren
'91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq
'94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq
'00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300)
Green Country Motorsports
Northeastern Oklahoma SCCA
96SEChick is offline   Reply With Quote
Old 02-13-2003, 03:21 PM   #5
fleaf
ok, now if I pump the clutch extremely fast, I can feel pressure building, but it goes away after I stop. Any suggestions of what might exactly be wrong would be greatly appreciated. Thanks..
Old 02-13-2003, 07:00 PM   #6
kalieaire
kalieaire's Avatar
kalieaire is an unknown quantity at this point
Send a message via ICQ to kalieaire
fleaf, as they we were saying before, it's probably your clutch master cylinder, or slave cylinder, or BOTH.
REPLACE THEM.
'93 240sx coupe
'93 taurus wagon
-kalieaire (maybe grinder too on special occasions)
kalieaire is offline   Reply With Quote
