Old 02-11-2003, 09:08 PM   #1
A Dying Devotion
A Dying Devotion is an unknown quantity at this point
Send a message via AIM to A Dying Devotion
WTF is going on
Well after driving my car today and getting in an accident on the rear passenger side corner my car does some wierd stuff. I will start accelerating in first and will hear a sound coming from either the front wheel or in the engine bay but this may sound dumb it goes something like this "chhhh" then the car seems to stop recieving gas and it slows down like 1mph then goes back up fine again. It will do this through all the gears every 10-15 sec. Also my idle is now funny it will go as low as 600 then jump up to 1300. Could this be a bad fuel pump? Yes I know the fuel pump is in the rear but maybe my ears are just tricked into thinking its coming from another direction. Not really sure.
Your my blessing in disquise, you make me realize, just where I want to be years from now.
A Dying Devotion is offline   Reply With Quote
Old 02-11-2003, 10:43 PM   #2
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
Sounds like your pump could be the problem. Symptoms point that way atleast. Pull the fuel line at the fuel filter, and put the keys on accessory. Place a bucket underneath the fuel line on the fuel pump side, and see if fuel flows (have a buddy turn the key over, but don't go crazy). If no fuel flows, or goes intermintally (sp?), the fuel pump needs replacement, or it just got knocked off the plumbing a little in the tank. Could be a fuel filter or spark plug / wire issue also.
"Pure adrenaline attached to a license plate.  Isn't it time to experience one yourself?"
                        -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 02-13-2003, 01:16 AM   #3
Anubis
Anubis's Avatar
Anubis is an unknown quantity at this point
Send a message via AIM to Anubis
If its the rear passenger side, then its the fuel system thats jacked. Check all the lines and fuel pump and stuff.
Anubis is offline   Reply With Quote
Old 02-13-2003, 03:20 AM   #4
adey
adey's Avatar
adey is an unknown quantity at this point
I may be way off, but the erratic idle could be a bad ground somewhere; maybe the impact knocked a ground cable loose somewhere?
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-13-2003, 08:33 AM   #5
A Dying Devotion
Well its still raining so I havent had a chance to check. Ill keep you guys updated.
