Old 01-06-2009, 06:26 PM   #1
bruceguy
bruceguy's Avatar
bruceguy is an unknown quantity at this point
s13 wiring help!! fusebox plugs missing home!!
ok, im building this 92 240 hatch, sohc
i hooked up everything where i think it should go.
but im left with three plugs behind the fuse box; gray 7 prong, brown 7 prong, grey 3prong. what are they for ???
i can turn over the engine, but there is no fuel coming from the pump,
witch harness should they be connected to?
so im stuck for the moment, any help would be great!!!
bruceguy is offline   Reply With Quote
Old 01-06-2009, 07:51 PM   #2
projectRDM
projectRDM's Avatar
Automatic transmission.
FSM tells all. Go read one.
FORMERLY R240NA
Old 01-06-2009, 09:06 PM   #3
bruceguy
bruceguy's Avatar
cool, i just checked out my friends 240, those two 7 prong plugs, are not even there,
i shouldnt mess with it then,
but my fuel pump is still not responding,
someone linked me to FSM on nicoclub, reading............
Old 01-06-2009, 10:18 PM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
by where the stock battery is located along the fender there is a big grey plug and a small brownish/red 8 pin plug from the engine harness to the chassis.
check your grounds, check your fuel pump fuse, finally if you've checked all else correctly, cut into the black/pink stripe wire on that brownish/red 8 pin plug i'm talking about and run a wire to it that's grounded. whenever the key's on and you're manually grounding that wire your fuel pump should run.
if your pump is running already you may have hooked up the fuel lines backwards. the fuel hose that comes right off of the fuel pressure regulator is your fuel return line, it does not connect to the fuel filter. double check that
gl,
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-06-2009, 11:59 PM   #5
bruceguy
bruceguy's Avatar
ok, the ten amp fuse went out, i put another one but that didnt work,
let me manually ground the fuel pump and see what happens.
btw, is the fuel pump on a 240 loud enough to hear???
thanks........
