Old 01-07-2009, 09:09 PM   #1
wrxn240
wrxn240 is on the path to ruinwrxn240 is on the path to ruin
Leaking coolant from hole in water pump?
I filled my shit up with coolant earlier and noticed coolant dripping on the ground. It's coming from a little hole in the bottom of the water pump. My guess is this is some sort of freeze plug or what? I don't think it's threaded. There's nothing is the FSM about it either....any insight?
wrxn240 is offline   Reply With Quote
Old 01-07-2009, 09:11 PM   #2
Sileighty_85
Sileighty_85's Avatar
Its the weep hole it means the seals are worn out in your waterpump and Needs to be replaced.
So you need a new waterpump.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-07-2009, 09:16 PM   #3
nissandrifter323
nissandrifter323's Avatar
nissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nicenissandrifter323 is just really nice
Send a message via AIM to nissandrifter323
Is it an sr or KA, i can get the SR Water pumps for 50 bucks brand new if you need it.
nissandrifter323 is offline   Reply With Quote
Old 01-07-2009, 09:17 PM   #4
wrxn240
damn thats shitty...its a KA
Old 01-07-2009, 09:45 PM   #5
reinvent
reinvent is an unknown quantity at this point
weep ass ssss
reinvent is offline   Reply With Quote
Old 01-07-2009, 10:19 PM   #6
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
just replace the water pump, it literally took me 20 min to do mine. iirc the fan blades are 10 mm, the water pump to front cover are 12 mm's dont forget to bleed it properly. enjoy.
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 01-07-2009, 10:30 PM   #7
reinvent
20 minutes per bolt. and 2 days to bleed.
Old 01-07-2009, 10:34 PM   #8
murda-c
murda-c's Avatar
why do people have so much trouble bleeding?
maybe it's the way they do it? do you guys drain coolant from the drain plug first or do you just take the pump off and replace it then fill up with more coolant without draining completely?
Is your climate control set to cold or hot?
I've never had a bleeding problem.
Old 01-07-2009, 10:37 PM   #9
theronin
theronin's Avatar
ur doing it wrong. for the fan, take 2 10 mm, one to hold the fan, the other to loosen the bolt. once the fan is off, if it takes you longer than 10 seconds for each 12 mm bolt, you seriously need to stop being a girly man. i will give you that bleeding our cars can be a pita, one of these would help methinks Greddy Radiator Breather Tank: S-Type Cap 8mm Diameter Hose swirl pot?
http://shop.ebay.com/items/__radiato...286.m104.l1198
