Old 01-21-2009, 11:55 AM   #1
MartyMcFly
MartyMcFly is an unknown quantity at this point
Alternator bolt keeps backing out.
Ka24e here. Curious , on the long alternator bolt, does it have a nut on the backside to keep it in place? Mine keeps squirming its way out. Sorry if this is an obvious question.
TIA
MartyMcFly is offline   Reply With Quote
Old 01-21-2009, 12:01 PM   #2
toointoxicated62
toointoxicated62 is an unknown quantity at this point
there should be one there its a long bolt and a nut that hold that bottom of it in. I was cleaning up my alternator cause it was full of oil so im 100% positive :P
toointoxicated62 is offline   Reply With Quote
Old 01-21-2009, 12:02 PM   #3
MartyMcFly
you my friend have been very helpful, thanks for not ragging on me Wish we could all be as friendly as this guy.
Old 01-21-2009, 06:36 PM   #4
projectRDM
projectRDM's Avatar
The OE nut is actually part of a plate, eliminating the need to use a wrench to hold it still when tightening.
FORMERLY R240NA
Old 01-21-2009, 06:40 PM   #5
vqboodah
vqboodah's Avatar
vqboodah is on a distinguished road
if the adjusting bolt keeps squirming out, the nut at the end of the bolt is called a tensioner block which holds tension to the belt. there's a locking bolt on the side of that block which locks it. adjust the belt to the right tension and tighten the bolt on the block. belt is still loose if you can twist it around.
vqboodah is offline   Reply With Quote
Old 01-21-2009, 07:41 PM   #6
MartyMcFly
thanks you guys, im gunna have to get under the car too see what you guys are talking about, All I did was twist the bolt back into its slot.. the belts dont squeal, but the bolt will back out in a few days. Is it possible for this plate to fall off or is it attached to the block?
Old 01-21-2009, 08:02 PM   #7
projectRDM
projectRDM's Avatar
Yes, if the bolt backed all the way out the plate would fall right out on the ground. You can replace it with just a regular nut, you'll just have to hold it still while you tighten the bolt.
FORMERLY R240NA
Old 01-21-2009, 08:03 PM   #8
yokotavia
yokotavia's Avatar
yokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enoughyokotavia will become famous soon enough
Send a message via MSN to yokotavia
locktight.
Banana boat chronicles
yokotavia is offline   Reply With Quote
Old 01-22-2009, 03:22 PM   #9
Om1kron
Om1kron's Avatar
Originally Posted by yokotavia View Post
locktight.
/thread..... fuck that bolt son!!!
Wayne Edwards
https://om1kron.blogspot.com
Old 01-21-2009, 11:09 PM   #10
VanduzerLancerES
VanduzerLancerES's Avatar
VanduzerLancerES is an unknown quantity at this point
Yeah, I replaced my alternator, and put the OEM plate back in and it only took 2 days for that to fall off. so make sure you tighten it down realllly good. I ended up just using a nut. much easier.
VanduzerLancerES is offline   Reply With Quote
Old 01-22-2009, 12:08 AM   #11
zylvia213
zylvia213's Avatar
Trader Rating: (36)
zylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond reputezylvia213 has a reputation beyond repute
Feedback Score: 36 reviews
Send a message via AIM to zylvia213
I had this problem w/ one of my coupes w/ an sr swap. The whole where the long bolt slides in actually is threaded in the rear. Some how it gets striped. All i did was go to the hardware store and bought me a long bolt same size as the stock one and a nut that goes with it and bam problem solved.
zylvia213 is offline   Reply With Quote
Old 01-22-2009, 03:01 PM   #12
MartyMcFly
Ok great, going to go pick up a nut, thanks folks for the cool responses.
