Old 01-22-2009, 05:46 PM   #1
obsolete
obsolete is an unknown quantity at this point
Another SR won't start thread...
I have a s14 SR in a s14 with a slim battery.
Usually, I could crank it for a while and it would eventually start. But now, it doensn't have enough juice to keep cranking long enough to start. I have to jump start it and it helps to press the gas to get it started. it idles fine and does not overheat once it starts. it backfires as soon as I start going and ok after that initial one. why won't it start right away? just keeps cranking for a while before it starts.
obsolete is offline   Reply With Quote
Old 01-23-2009, 01:10 AM   #2
Mr.s13r
Mr.s13r is an unknown quantity at this point
check yo timing buddy,and injectors and spark plugs, everything that deals with ignitions
Mr.s13r is offline   Reply With Quote
Old 01-23-2009, 03:13 PM   #3
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
i would say timing, otherwise check your battery for the correct voltage. also get it load tested. sounds like you either need tuning or if you have a tps (i'm not to familiar with sr's) maybe you want to look into that.
supreme_1 is offline   Reply With Quote
Old 01-23-2009, 03:20 PM   #4
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
Who did the wiring? The original swap wiring in my car was so shitty it sometimes couldn't start just because there was so much voltage drain, etc
renegade_ewok is offline   Reply With Quote
