Old 01-26-2009, 06:04 PM   #1
SoSideways
SoSideways's Avatar
Lug nuts that keep turning...
Search turned up a bunch of useless results for me, and I honestly have no idea what I'd type in to get the "right answer".
Anyway.
For some reason, I cannot tighten a couple of my lug nuts to 85 ft-lbs of tq on the front left wheel.
Right front wheel were all good to go, but left front for some reason is giving me shit.
Wheels: VS-KF
Lug Nuts: Muteki open end spline drive lug nuts (red ones)
I'm wondering if the lug nuts are getting owned and basically shearing off when I'm tightening them or something, as the coating on them have all but come off...
PS - I've never had a problem with the black Muteki lug nuts, these red ones so far suck... the coating on them are flaking off where the conical seat part is.
PPS - I don't think it's the wheel studs, as they aren't spinning, and I pulled them through the hub pretty much all the way before I even put the lugs on the wheels for the first time.
Logan... help?
Old 01-26-2009, 06:09 PM   #2
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
did you check tightening the lugs without the wheels on?
let me get this straight... the lugs WON'T stop spinning? cause it could be that the thread is busting up and not "stoping" them from spining... kinda like when you keep tighetning a bolt too much...
is that what you mean?
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 01-26-2009, 06:10 PM   #3
LA_phantom_240
LA_phantom_240's Avatar
Location: Louisiana. LA is for Louisiana. L.A. is Los Angeles.
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
So.... what's the problem here? I see where you complained about the nuts, etc... but what is the issue here? Are the threads in the nuts pulling out? Is the stud turning? Is the stud breaking?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-26-2009, 06:11 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
u sure the stud isnt spinning with the lugnut? i recently had a problem like this and i had to take off the whole hub to reach the back of the studs. a bit of weld on each one worked great for holding it still while i used an impact
lexus baby
5t341tH is offline   Reply With Quote
Old 01-26-2009, 06:13 PM   #5
DMaxUSA
DMaxUSA's Avatar
DMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond reputeDMaxUSA has a reputation beyond repute
have you swapped around lug nuts to check whether its the lug nuts or stud? I agree with Bejota though, it kinda sounds like you have a messed up thread on the stud
dmax-us.com
DMaxUSA is offline   Reply With Quote
Old 01-26-2009, 06:13 PM   #6
!Zar!
!Zar!'s Avatar
Sounds like it's your studs.
Old 01-26-2009, 06:25 PM   #7
s13drob
s13drob's Avatar
Trader Rating: (29)
s13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymores13drob is not welcome here anymore
Feedback Score: 29 reviews
[quote=!Zar!;2594912]Sounds like it's your studs
+1. studs broke loose on the back.
s13drob is offline   Reply With Quote
Old 01-26-2009, 06:26 PM   #8
SoSideways
SoSideways's Avatar
I just looked at the studs, the studs look ok. Doesn't look like any of the threads are busted.
The nuts seemed ok too, didn't look like the threads are pulled out.
Haven't swapped around nuts yet.
And I found a mark on the stud, kept in mind where it was, tried to tighten the lug nut some more, and when I pulled everything back and looked at the stud again, it didn't move (it was less than 360 degrees so if it moved the mark would have moved with the lug nut).
Old 01-26-2009, 06:30 PM   #9
allntrlundrgrnd
allntrlundrgrnd's Avatar
replace studs. that was happening to me, replaced them= all good
Old 01-26-2009, 06:31 PM   #10
TheRonTom31
TheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfectionTheRonTom31 is close to perfection
Send a message via AIM to TheRonTom31
well if you can put them on and they spin and then take them off its clearly not the studs. cause if the studs broke free you wouldn't be able to thread the lugs off the stud
TheRonTom31 is offline   Reply With Quote
Old 01-26-2009, 07:03 PM   #11
SoSideways
SoSideways's Avatar
Ya, they've been on and off a few times.
Although I do have a couple of spares, I think.
I don't know... I am starting to really hate this car... one thing after another... godamnit...
Old 01-26-2009, 07:31 PM   #12
projectRDM
projectRDM's Avatar
Try it without the wheel on so you can really see what's happening.
FORMERLY R240NA
Old 01-26-2009, 07:31 PM   #13
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
I don't know... I am starting to really hate this car... one thing after another... godamnit...[/quote]
Welcome to my world sir . Once you fix that stud...something else will go bad.
I stick by a rule of 3. At all times 3 things have to be bad on the car. If I fix one of those things I set myself up for another part breaking of which I have no control. I know it sounds crazy maybe superstitious, but it's true for me...
I love my S14 anyways though, plus I have my my spare Volvo240
The Chad is offline   Reply With Quote
Old 01-26-2009, 07:36 PM   #14
LA_phantom_240
My S14 LIVES by the rule of three.
1)heat
2)blower
3)sunroof weather strip
Old 01-26-2009, 08:00 PM   #15
SoSideways
SoSideways's Avatar
Alright, next time the car is back up on jackstands I'll take a look at the lug nuts/studs situation with the wheel off and report my findings in this thread.
Thanks guys for the input.
Old 01-26-2009, 08:02 PM   #16
The Chad
The Chad's Avatar
LA Phantom:
Spread the word sir, no one believes me
Old 01-26-2009, 11:51 PM   #17
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
give me the vs-kf. i'll fly down and fix your problem and bring you replacement wheels also. those wheels are too heavy anyways
slideways2004 is offline   Reply With Quote
Old 01-26-2009, 11:58 PM   #18
articdragon192
articdragon192's Avatar
Same happened with me. I couldn't torque my lugnuts down, but I could remove the lugnut still. The splines on the stud might be almost completely stripped. You might want to check the splines on the hub itself too, as they might be stripping as well.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 01-27-2009, 07:17 AM   #19
SoSideways
SoSideways's Avatar
I thought the "splines" on the hub were basically not there, but it forms when you pull the studs through to create that spline lock effect?
That's what I've read... not sure how true that is.
Thanks for the advice, I'll check it out.
Old 01-27-2009, 08:17 AM   #20
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Correct, the hubs are NOT splined, only the stud is splined.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-28-2009, 06:58 PM   #21
SoSideways
SoSideways's Avatar
So I got the car up in the air, and pulled the wheel off and checked all the studs.
They're all tight, not spinning, and none of the threads are stripped or coming off.
None of the lug nuts on that side is fucked up either.
So then I put the wheel back on, and I think the reason for the lug nut issue is that, the lug nuts weren't 100% centered in the holes on the wheel, which I just made sure that all 5 of them were this time.
Haven't tightened it with a torque wrench yet, but so far it seems promising.
Then I moved on to the passenger side front wheel, and I've always wondered why the rotor keeps catching on the pads instead of being able to keep spinning round and round.
Well, there was a wobble... Obviously it couldn't be Work wheel actually releasing a wobbly wheel to the general public, and since the wheel hasn't seen any real driving on it yet, it can't be bent.
So I started taking the brakes on that side off and looking deeper into the problem.
Long story short.
It was the wheel studs.
The knurl area on those studs STUCK OUT past the the hub's face.
And yes, I got different studs from the same place that I got them from for some reason, but that's not important for my post because I've already contacted them about it.
Anyway, so now it looks like the car's going to sit on jack stands for at least another week...
Sigh...
Telling you guys, 1 thing after another...
Old 01-28-2009, 07:18 PM   #22
TheRonTom31
You have a wife so this may be harder for you but I know that when my car is giving me problems and then tied up waiting for retard parts nothing calms me down better than a good strong HATE FUCKING.
you need to pound some vagina to the point of pelvic bruising on both behalves.
Old 01-28-2009, 07:50 PM   #23
The Chad
The Chad's Avatar
^^^ I just..well...I can not disagree^^^ hahahha
Old 01-28-2009, 07:51 PM   #24
The Chad
The Chad's Avatar
600 Fricken HUndred Baby!!!! sorry OP
Old 02-02-2009, 10:47 AM   #25
SoSideways
SoSideways's Avatar
Alright, I promised pics, here they are.
A view from the top reveals the problem
Close up from the side
Oh look at all these studs w/ their knurl area all sticking out
Here are the difference between all 3 studs that I got. The ones that came on the hub is on the right. The first batch of studs I got on the left, and the 2nd batch of studs I got in the middle
Look closely at the knurl area on these studs
So yeah, still waiting on vendor to email me back...
