Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Local / Regional / National > USA > Mid-Atlantic States
Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia.
Old 02-11-2009, 01:30 PM   #1
Zerolift Autolab
Zerolift Autolab's Avatar
Zerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant futureZerolift Autolab has a brilliant future
Send a message via AIM to Zerolift Autolab
Zerolift - Cincy, Oh - Shop S13 Vert Build Up
Zerolift Autolab Drift S13 Vert Build Progress
Chassis :
1994 S13 Vert
Fully Stripped
Media Blasted Remove All Paint, Seam Sealer, etc ...
Cut all Vert Top Mounts, Motors, Linkage Out of the Way
Extend Front Frame rails
Build Supports and Framework for V Mount
Box in rear seat compartment and vert linkage area
Box in Spare Tire / Floor, Build Box for Fuel Cell
Roll Cage Fabricated
Underbody Cage for Fuel Cell
Stitch Welded
Front End Tubbed
Cage & Car Was Painted
Stainless Hard Brake Lines were Fabricated using AN Fittings
Engine :
SR20det Motorset -
87MM Bore
Lightened Rotating Assembly ... -10 lbs !
JE Pistons
Manley Turbo Tuff Rods
ACL Race Coated Bearings
Port Flow Cylinder Head, Valve Job, Port, Polish, The works........
Supertech Springs & Retainers
Kelford Camshafts
Apexi Head Gasket
Custom V Mounted Intercooler
Custom C&R Radiator
Custom Radiator Inlet/Outlet Flanges - AN
Peak Boost Top Mount Manifold
GT3076R Turbo Polished & V Band
44mm Tial Wastegate
All Oil & Coolant AN Fittings & Stainless Braided Line
Cryo2 Intercooler Coil
Fuel System :
ATL Fuel Cell
Bosch High Pressure Fuel Pump
Electronic Level Sender
Stainless & AN Feed / Return Lines
HKS 740cc Injectors
Drivetrain :
5 Speed Sr20det Transmission
Silvia C's Short Shifter
Driveshaft Shop Aluminum Driveshaft
Driveshaft Shop Axles - Stg1
OS Giken LSD
Custom Cryo Treated Final Drive
ACT Extreme Clutch
Nismo Slave
Custom Clutch line - AN & braided
Suspension :
Subframe Removed & Painted
Solid Aluminum Subframe Bushings Installed
IKEYA Formula Front and Rear Control Arms
Peak Performance Suspension Linkage
Function & Form Remote Reservoir Coilovers
Carbing Front Strut Bar w/ Bmc Stopper
Brakes :
Wilwood 13" Big Brake Kit
Wilwood Brake Lines
Z32 Rear Brakes
Hydraulic E-Brake - Stainless Hard Line w/ AN
Z32 Brake Master Cylinder
Exterior / Interior :
JDM Front End Conversion
Origin-Lab Aggressive 4pc Kit
Origin-Lab Wide Front Fenders
Origin-Lab Wide Rear Over Fenders - Flexed
C-west Carbon Side Mirrors
Seibon CF Hood - Cut for V mount
Seibon CF Trunk Lid
Seibon FRP Doors
Seibon Carbon Kevlar Seats
Custom hard mounted seat brackets
Sparco Steering Wheel
Sparco 3" Harnesses
Custom Aluminum Battery Box
DEFI > All Gauges incl Tach
Defi Control Unit
Custom Carbon Gauge Cluster Din w/ Defi Tach
Wheels :
Enkei RPF1 SBC Coated 18x9.5 & 18x10.5
SPONSORS :
ACT Clutch
ATL Fuel Cell
SEIBON
Origin-Lab
ENKEI Wheels
Function & Form Suspension
Peak Performance
Peak Boost
Bobs Braided Lines
International Engine Supply
Contact:
Phone - 513-874-2508
AIM - ZLR0bert
Email - [email protected]
Zerolift facebook - http://www.facebook.com/Zerolift
Zerolift Autolab is offline   Reply With Quote
Old 02-11-2009, 04:47 PM   #2
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Sweet. Is this going to stay permanently topless?
ryguy is offline   Reply With Quote
Old 02-12-2009, 03:04 PM   #3
karforty5
karforty5 is an unknown quantity at this point
Dont want this thing behind me on the highway!!! Whats your HP goal?
6 Million ways to die, Choose 1
karforty5 is offline   Reply With Quote
Old 02-12-2009, 04:38 PM   #4
Zerolift Autolab
450whp easily - but more than likely will be tuned to about 400.
Race gas and 25-26lbs it should make over 500 without breaking a sweat.
Contact:
AIM - ZLR0bert
Old 02-13-2009, 08:21 PM   #5
alexander500
alexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond repute
Who are you going to get to drive this beast?
Say Nate Brasz.
alexander500 is offline   Reply With Quote
Old 02-27-2009, 11:52 AM   #6
Rick-95ZE
Rick-95ZE's Avatar
Trader Rating: (22)
Rick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfectionRick-95ZE is close to perfection
Feedback Score: 22 reviews
lookin good, its about time
1997 Nissan 240sx SE(Rb25det+GT35r= 486whp on 93pump):http://zilvia.net/f/premium-member-b...oject-2-a.html
Originally Posted by PHLIP
Take it literally, kill someone, aim for the face in whatever method you use to do so, and it is the most righteously gratifying feeling ever, almost orgasmic.
Rick-95ZE is offline   Reply With Quote
Old 02-27-2009, 11:56 AM   #7
Om1kron
Om1kron's Avatar
your door bars scream serious business.
Wayne Edwards
https://om1kron.blogspot.com
Old 02-27-2009, 09:10 PM   #8
Zerolift Autolab
Really ? I was hoping for "Get em ricky bobby"
Thanks for all the positive feedback
Contact:
AIM - ZLR0bert
Old 03-13-2009, 09:50 AM   #9
orangejdmsilvia
orangejdmsilvia's Avatar
orangejdmsilvia is an unknown quantity at this point
Send a message via AIM to orangejdmsilvia
sickkk good luck!!
Driftlineusa.com - TMFopposition.com
orangejdmsilvia is offline   Reply With Quote
Old 06-16-2010, 06:58 PM   #10
Zerolift Autolab
Contact:
AIM - ZLR0bert
Old 06-17-2010, 03:13 PM   #11
Leetfade
Leetfade's Avatar
Leetfade is an unknown quantity at this point
Those going in my car?? ~.^)b
Leetfade is offline   Reply With Quote
