Old 03-05-2003, 10:22 AM   #1
Travis240
Travis240 is an unknown quantity at this point
KA Low 13s in A KA-T
Hello,
I am In the process of building a KA-T single cam motor, and I have several questions:
1.)What hp level do I need to hit to run in the 13.4-13.1 range?
2.)How hard is it to pass (tailpipe only ) emissions with a standalone?
3.) How likely am I to blow up my motor if I've never tuned a standalone before?
This and any other insights on turboing the single cam motor would be appreciated.
Thank You,
Travis
Travis240 is offline   Reply With Quote
Old 03-05-2003, 01:26 PM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Probably 250rwhp and a good launch should get the low-mid 13s.
It depends on how it's tuned, and if it's a cold start or not. Put another catalytic convertor on your car before testing if you're that worried.
Yup. That's why dyno shops exist. That's also why they charge a lot of money. Cuz they don't (or at least shouldn't) blow motors tuning stand-alones.
As far as insight... search and goto my website below. There is some install (of ka24de) turbo pics, and a writeup.
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 03-05-2003, 02:09 PM   #3
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
as far as insights: the only high HP single cam KA turbo I've heard of had major overheating problems at the start... not sure if it's a block, head, or general cooling system design that causes it. he (Adam Hutchinson on FA) runs a fluidyne radiator now, though.
AceInHole is offline   Reply With Quote
Old 03-05-2003, 02:51 PM   #4
TrueSlide
TrueSlide's Avatar
TrueSlide is an unknown quantity at this point
Send a message via AIM to TrueSlide
To pass emissions, I heard, if you have some way to adjust fuel, you can lean it out for a few seconds to pass(kinda risky). KA-T should be easy in the low 13s, ever seen SDS SOHC KA-T, 13.06 on street tires, no LSD, no internals @ around 10 PSI.
http://www.sdsefi.com/features/240sx.htm
Real men drive s13s.
#240sx on EFnet
TrueSlide is offline   Reply With Quote
