Old 04-02-2009, 03:30 AM   #1
frankenfresh
frankenfresh's Avatar
frankenfresh is an unknown quantity at this point
power fc need a wideband?
I just picked up a power fc for my red top sr20 and someone mentioned that they thought i would NEED a wideband O2 sensor for it. is this true? or does it just use the stock narrow band?
if it uses the stock O2 sensor, will the commander give me readings on how lean/rich I'm running? or will i still need to pick up a wideband for that?
frankenfresh is offline   Reply With Quote
Old 04-02-2009, 03:32 AM   #2
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
i have a power fc and no wideband.
you need a wideband to read your a/r's.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 04-02-2009, 03:37 AM   #3
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Umm...Power FC doesnt give you A/F readings.
You need a wide band sensor to tune it, even then, it doesnt connect directly to it.
CLICK HERE!!!
Old 04-02-2009, 03:47 AM   #4
frankenfresh
right, the wideband is its own separate unit, simply telling me what air fuel ratio i have, at which point I use my power fc to make corrections and adjust fuel. got ya. thanks
Old 04-02-2009, 04:03 AM   #5
frankenfresh
while we're on the subject. any preference as to wideband set ups? some better than others?
Old 04-02-2009, 05:04 AM   #6
S14DB
AFC #1
S14DB's Avatar
You will want something that logs AFR, RPM and TPS. RPM and TPS though a input. Internal logging is easier then carrying a laptop around.
Old 04-02-2009, 05:10 AM   #7
HYPNOTIK
HYPNOTIK's Avatar
HYPNOTIK is an unknown quantity at this point
Send a message via Yahoo to HYPNOTIK
Ray, you actually used my picture, cool. LOL
HYPNOTIK is offline   Reply With Quote
