Old 04-15-2009, 07:49 PM   #1
LoneStarSilvia
LoneStarSilvia's Avatar
LoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond reputeLoneStarSilvia has a reputation beyond repute
Need help identifying output flange.
Just found out my fucked up output shaft isn't quite a S14 one like I thought.
This isn't my output shafts, but this is for reference.
One is ofcourse the S14 shaft, and the other is a NA Z32 shaft.
The one's I have are a mix of those. They look exactly like the Z32 shaft, with that gear looking thing at the base of it, however it has the 6 bolt, 3x2 bolt pattern of a S14.
I tried searching and haven't come up with anything. The Z32 TT flange uses the 6x1, and as far as I can find, the J30 either uses a 5x1 or 6x1 pattern.
I was told I might have S14 ABS shafts, but I wasn't aware of their being a difference between those and non-ABS shafts.
BTW the whole diff unit is from another car, hence why I'm trying to figure out where it came from.
Thanks.
LoneStarSilvia is offline   Reply With Quote
