Old 04-26-2009, 11:15 AM   #1
Indabay
Indabay is an unknown quantity at this point
Frame Damage - Opinions on repair
Hi i bought an 1990 240 recently, got a good deal but recently when i had it in a position to see under it i noticed some damage around the frame, which seems to be affecting the suspension geometry and strucural integrity of the front clip.
It looks like the passenger side frame rail has taken a blow probably from a curb but im not sure, i have never dealt with frame damage so im just looking for suggestions so i can get everything lined up again the nismo power brace has a bolt missing at the top into the frame and there is a brace at the front that connects to both rails which has broken loose.
My shits F****D UP what can i do?
Indabay is offline   Reply With Quote
Old 04-26-2009, 11:22 AM   #2
Banegraphix
Banegraphix's Avatar
Banegraphix is an unknown quantity at this point
Any auto body repair shop should have a frame straightening machine not sure on how much that cost but thats a better option than buying another shell
Banegraphix is offline   Reply With Quote
Old 04-26-2009, 11:23 AM   #3
tangch
tangch is an unknown quantity at this point
get a rolling shell, and swap everything over.
tangch is offline   Reply With Quote
Old 04-26-2009, 11:23 AM   #4
ATLspeed
ATLspeed's Avatar
ATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to beholdATLspeed is a splendid one to behold
radiator core support needs to be re-tacked/welded back into its original position. Its not that bad in my opinion because mine is MUCH MUCH worse.
If I try to jack my car up from under my rad support, the rad support will begin to move only. (but your not supposed to jack the car up that way anyway)
93 s13 Vert - 2jz/cd009 -- parted/sold
95 Supra Turbo
ATLspeed is offline   Reply With Quote
Old 04-26-2009, 11:54 AM   #5
Indabay
After you repaired your frame do you still notice any problems that affect the suspension much? Did you have a professional do the repairs or did you pull it back yourself? I was messin around after i noticed it and it seems like with the support free the frame is fairly malleable. I was thinking i could beat it back into position but im more concerned with the suspension geometry still being tweaked oh well.
Old 04-26-2009, 11:58 AM   #6
ixfxi
Guest
Posts: n/a
but hey......... you have the NISMO POWER BAR
thats all that matters.
Old 04-26-2009, 09:36 PM   #7
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
lol
what a jackass..
if you want to be ghetto, get tie strap and crank the two together and weld it and call it a day.
or you can take it to a shop and have them do their thing.
babowc is offline   Reply With Quote
Old 04-26-2009, 02:15 PM   #8
GSXRJJordan
GSXRJJordan's Avatar
That sucks, but like ATL said, it's not that bad - that's not "frame damage" in my opinion. You should be able to have a body shop weld that up for you no problem.
Old 04-26-2009, 09:56 PM   #9
aoiken3
aoiken3's Avatar
aoiken3 is an unknown quantity at this point
i'd hardly call that frame damage. just do what the other said and go to a shop to have them weld it back together for you. if you want to see frame damage, come by my friend's house. lol
おれのシルビア大好きだよ!!!
aoiken3 is offline   Reply With Quote
Old 04-27-2009, 10:24 AM   #10
Indabay
Yeah im probably going to take it to a shop and see what they think of it, maybe get it up off the ground to take a look, but it drives cool for dd, i just want to get the suspension all aligned so i can fix some other things, I have 18's on it that are too close for comfort to the coilovers and it rubs a bit in hard cornering so drifting and performance driving are on hold till i get it all straightened up. But its cool to know its workable.
