Old 05-25-2009, 01:23 PM   #1
Driftedtofu
Driftedtofu's Avatar
Driftedtofu is an unknown quantity at this point
Power Steering Boot Broken...
Anyone got any advise on how to fix this? Passenger side boot is completely split in two leaking power steering fluid everywhere...
Driftedtofu is offline   Reply With Quote
Old 05-25-2009, 02:16 PM   #2
Sileighty_85
Sileighty_85's Avatar
Rack and pinion seals are worn and need to be replaced
The boots are only to keep dust and crap away from the seals.
What type of fluid are you putting in the P/S system?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-25-2009, 02:30 PM   #3
808DRFTR
808DRFTR's Avatar
808DRFTR is an unknown quantity at this point
Replace the rack seal and replace the boot, Or replace the rack with a known good rack, or upgrade to a HICAS Rack.
808 All Day, Livin The HILIFE!
808DRFTR is offline   Reply With Quote
Old 05-26-2009, 09:46 AM   #4
nismo_drifter
nismo_drifter is on the path to ruinnismo_drifter is on the path to ruin
dont mean to thread jack...but is hicas rack really an upgrade and how is it???
nismo_drifter is offline   Reply With Quote
Old 05-26-2009, 07:21 PM   #5
Shadowhunter
Shadowhunter's Avatar
Shadowhunter is an unknown quantity at this point
Replace the rack,replacing the seal is ghetto and chances are if the rack is that worn then you will have problems in the future.
Shadowhunter is offline   Reply With Quote
Old 05-26-2009, 07:41 PM   #6
94_240sx
94_240sx is on a distinguished road
Word. Reman rack should be good enough. You can upgrade tie rods and ends at the same time. Whatever you do, alignment is recommended after the work.
94_240sx is offline   Reply With Quote
Old 05-26-2009, 08:11 PM   #7
ryguy
ryguy's Avatar
ryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfectionryguy is close to perfection
Get some stiffer rack bushings while you're replacing the rack too, they're cheap.
ryguy is offline   Reply With Quote
Old 05-30-2009, 11:05 PM   #8
jserman
jserman's Avatar
jserman is an unknown quantity at this point
I have the same prob... luckly I have a spare rack in my parts car....where do I get stiffer rack bushings????
jserman is offline   Reply With Quote
Old 05-30-2009, 11:27 PM   #9
ryguy
ryguy's Avatar
Energy Suspension makes urethane ones. I'm pretty sure somebody makes solid bushings, but I cant remember who.
Old 06-22-2009, 02:22 PM   #10
markapple0507
markapple0507's Avatar
markapple0507 is an unknown quantity at this point
what is a Reman rack and where can i get it. oh and about the energy suspension bushings, i just grabbed some yesterday and it came with s13 passenger when i needed it for the s14. i think i remember reading somewhere that this is the case with all of their shipments. can anyone comment on this
EDIT: my bad with a little browsing the forum i found out reman means remanufactored
markapple0507 is offline   Reply With Quote
Old 06-22-2009, 02:43 PM   #11
slider2828
slider2828's Avatar
Remanufactured racks you can get it from anywhere, but I would use Napa ones or A1Cardone ones....
HICAS racks are an upgrade because they have a quicker steering ratio, so you turn less on the steering wheel to get the same steering angle vs stock.
Your broken boots probably caused the leak. ALWAYS replace your boots. Boots keeps direct from your seals, once dirt and rocks get it, its basically sand paper to your rack seals and hence the leak.
Turn and Burn!
Old 07-29-2009, 10:13 PM   #12
eytsics
eytsics's Avatar
eytsics will become famous soon enougheytsics will become famous soon enougheytsics will become famous soon enougheytsics will become famous soon enougheytsics will become famous soon enough
I can rebuild your rack and pinion
Just PM me.
eytsics is offline   Reply With Quote
